Hello Kacole, I'm just down the road in Greenville and running a similar tractor, a M 6800. Had my grapple for 5 years and used it a tremendous amount. My bucket hasn't been used since I got the grapple. I would ask you several things. First, what do you plan to do with it ? Heres what I do most.
1. Clean up chainsaw debris. I maintain miles of woods roads that are constantly growing in. I wald along the roads with a pole chainsaw, fell saplings and limbs right into the roadway, and then use my grapple to scoop them up. I drive forward slowly pushing as I go, and collect a pile bigger than the tractor. Then I either push it aside into a pile or pick it up and carry it to a pile. This works great. I have a 48" Markham heavy duty with 1/2" main tines
2. Clear land---I push over small trees (up to 6") and other undergrowth along the river and pick them up and create piles. Now here is where you need to consider your width. My 48" will pick up anything the 72" will. Even though it it engages the ground on a 48" swath, it collect limbs over a much wider path as the limbs tend to grab each other. But my 48" will out dig a wider one, hands down. I often pluck out trees by the root balls, by dipping my tines under it, driving forward, and curling up. I could not do this with a wider one as easliy. So if you want to clear land and uproot trees, go narrower. This is very important. Its kinda like a shovel. If you dig up a tree, you use a pointed shovel, not a wide snow shovel. So dont be afraid of a narrow grapple. It digs way better and picks up just as good as a wider one. It also would be ligher and less expensive to build.
