Grapple Pics of my new Grapple!
   / Pics of my new Grapple!
Was the third-function a Kubota item, or another brand? And did you install it yourself or have the dealer do it?
It's a WR Long 3rd function valve, and I had my dealer do the install.
Man that is really nice. I have never had a grapple, does it increase the risk of grille / front end damage from sticks and stuff?
It really looks awesome though, rarrrr! Go get em!
I plan to weld a piece of expanded metal across the back of the grapple to reduce the possibility of a stick/log poking through and hitting the grill or the hyd fittings going to the grapple arm.
Stu
   / Pics of my new Grapple! #14
I just bought the markham 60 inch Grapple, and I never thought about a stick poking through. Maybe a piece of walkway grating like we use on cat walks at work will do the trick, and keep visability high. I'll let you know.
   / Pics of my new Grapple! #15
NICE NEW TOOL!
Hey on a side note, the photo of your tractor in the trees is what I want my p5 acres to look like some day..... 1 acre at a time... here.
Cheers!
NICE NEW TOOL!
Cheers!
Thanks, it's about 5.5 acres I have cleared and fenced, the rest of the property outside the fence I have left natural woods with some food plots.
Stu
   / Pics of my new Grapple! #17
Those are some good pictures. I especially like the Grapple and Valve Kit.
Nelson
W. R. Long Inc.
Nelson
W. R. Long Inc.
Thanks Nelson!
I have been very pleased with my setup, feel free to use these pics if want to.
Stu
   / Pics of my new Grapple! #19
The WR Long kit works well - I have one on L4310 - the only issue I have had is the crimp on one of the hoses went bad after about ten hours...and PAIGE TRACTORS replaced the bad hose - and paid for half the cost of the other line as well. If you are in Central Texas - check out PAIGE TRACTORS in PAIGE, TEXAS for your WR. Long items.
Your grapple set up looks great - I built my own and on the grill I welded class 1 intergrated safety grate (pricey but worth it).
Look around steel yards / scrap yards - you may find it. I never worry about brush now - as the the spacing is 1 inch by 3 inch rectangle shape.
Good luck with your new grapple.
   / Pics of my new Grapple! #20
I'm getting ready to purchase the W R Long OBG but not sure which size to get, 48" or 56". 56" has two grapples -vs- one grapple for the 48".
Tractor is a Bobcat CT230. Is wider better if the tractor will handle it. 56" grapple is 460 lbs. Opinions please.
2003 Walk-Behind Automatic Seed Spreader (A55851)
2003 Walk-Behind...
MD ELECTRIC GOLF CART WITH BATTERY CHARGER (A53424)
MD ELECTRIC GOLF...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A53421)
2018 Bobcat T590...
