TOMLESCOEQUIP
Platinum Member
I'm thinking of installing a pellet insert in my wood burning fireplace. I currently have a heatilator insert that was built into the original masonry fireplace when our house was built
(it is the firebox & has a standard damper & a standard size opening).
The Amish mason who installed the original unit was a great mason, but not a PEH installer. He bricked over the duct work in the firebox that should have been hooked up to provide outside air for combustion, & also replaced the metal fan grates (for intake & output air to the built in circulation fan) with fancy brick work with gaps in between........
Looks much better than the black tin grates that came with the heatilator kit, but cuts the cfm of the air the fans can move by probably 50% or more.
I have glass doors on the FP now, but still go thru way too much wood for the heat value I'm getting out of it. I burn hardwood cutoffs from a local lumber mill, clean square sawed 4x6x12 to 8x8 x16 inch chunks........some smaller, but you get the general idea.
I used to buy a large tandem dump truck load heaping from the sideboards delivered for $175, & went thru about 3 loads a year. Now the same load is over $300. Plus we still use nat gas as we aren't there to feed the fire 24-7.
It got me thinking about capping of the fireplace with a pellet insert & being able to dump a bag of pellets (or corn) in it & letting it do its thing. Since I'm spending about $1000 a year now on wood, having to buy pellets wouldn't make the difference in cost too bad for me, since I don't have access to free firewood.
Anyone know anything about what brand to buy or have any experience with these ??
I'm looking for one with a good reputation from a company that's been around & will be around if & when I may need parts & service.
I've looked at units at a local farm store & the door handles were already broken off some of their display models !
Thanks.............
Tom
Thanks.............
Tom
