Part number for Turn Signal cover
   / Part number for Turn Signal cover #1
riptides
Super Member
Northern Virginia
Kubota ZTR, RTV, MX6000
B7800 HSD - Looking for a part number for the inside rectangular turn signal cover. Right side as your sitting on the tractor.
Mine seems to have gone missing, and I did not hit anything. A bit odd that it just dropped off.
   / Part number for Turn Signal cover #2
The one on the rops? It is called the winker light and I just had to buy 2 for my left side. I think that they are all the same. Lens part 37410-52730
   / Part number for Turn Signal cover #3
Hi bigboyga--just put my son on a flight back to Atlanta where he lives with his wife and teaches at Emery U. Anyway, I believe you are correct about front/back left/right being all the same, and I can verify that lens part number as I, too, have had to replace several that not so mysteriously went missing. Now I glue them on with a silicone adhesive that dosen't dry hard. Kind of a silly thing to have to be messin' with.......Regards, Mike
bigboyga Thanks for the quick turnaround. And welcome to TBN!
themichelob Thanks for the confirmation, and great idea about the silicone.
I usually inspect the rides after I work them, but this weekend, I left the B out, and when I returned to fetch it, I noticed it was missing. I suppose it fell off, I am not happy that it did. Those sort of things should be catagorized under parts for life. Now I need to inspect all my little plastic parts.
Must be ethanol in the air. :) :) :)
   / Part number for Turn Signal cover #5
i emailed that parts diagram. you can always go to messicks.com and request more parts info if needed. the lens are like $5.00 each.
2018 PETERBILT 579 SLEEPER (A51222)
2018 PETERBILT 579...
2006 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2006 Toyota Tundra...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
1271 (A50490)
1271 (A50490)
1272 (A50490)
1272 (A50490)
1270 (A50490)
1270 (A50490)
