Pallet forks on your FEL
   / Pallet forks on your FEL #21
Yes, 1 1/4" solid.
   / Pallet forks on your FEL #23
Justin, sorry for the late reply, but I have the horst welding 3000 lb. forged tine model with my 4310, 300 cx. which came from JD dealer, I like them better than the JD model because they have a higher back which helps prevent loads from spilling over the back. They were a little pricey around $900.00 but are very heavy duty and great for moving all kinds of bulky loads like logs etc. came in handy lifting tripled up 16 ft. 2x12's when building a shed (for the tractor). be very careful when lifting capacity loads off a high truck, as you lower the loader the weight moves forward exceeding capacity then if the load is not perfectly centered it tends to want to throw the tractor on its side, not just lift the back wheels of the ground, (almost happened to me). always use max. ballast and be ready to drop your loader fast if you get in trouble with raised load, it will usually help, good luck.
John,
   / Pallet forks on your FEL #24
Does anybody have pics? I would like to see my options in the pallet fork realm. I am looking to put them on my 4720.
Thanks,
D.
   / Pallet forks on your FEL #25
D.
I'll try to post pictures of my Horst welding forks, have not figured out how to post good pictures.
John,
   / Pallet forks on your FEL #26
Well that came out O.K., here is another picture
   / Pallet forks on your FEL #27
Wow, those do look heavy duty. The more I look at the pictures, the more applications I can think of for them...
Thanks,
D.
That looks great JB!
You wouldn't want to rent that to me for about 6 months would you? /forums/images/graemlins/grin.gif
   / Pallet forks on your FEL #30
I love my FEL. I am going to order a fork setup for my 4720 with 400X. Thanks for the pics.
D.
Pickup Instructions (A55272)
Pickup...
2148 (A58376)
2148 (A58376)
2006 CATERPILLAR 304C (A58216)
2006 CATERPILLAR...
Case 2390 Tractor (A59814)
Case 2390 Tractor...
2021 Husqvarna YTH18542 42in Riding Mower (A56859)
2021 Husqvarna...
Lincoln Electric Ranger 10000 AC/DC Welder Generator (A56857)
Lincoln Electric...
