"Over-maintaining" a vehicle....
   / "Over-maintaining" a vehicle.... #1
3930dave
Super Member
Canada
Ford 3930
Was on the NGK site, checking a plug listing. Came across this review, thought I share, in case anybody needs a laugh.... :thumbsup: Rgds, D.
NGK 2262 ZFR5F-11 Nickel Spark Plug
Fronzie
December 25, 2012
Endured 230,000 miles!!!
In 2001, I purchased a 1997 Honda CR-V, which I am still driving daily, with approximately 240,000 miles on the odometer. Last month, as I was leaving my work, for the first time, my CR-V would not crank. Being that it has been so faithfully dependable, I was certain that it had to be a major issue; especially since I had arrived to work that morning with no obvious issues.
After having my CR-V fail to crank (for the first time ever), finding alternative transportation home, and having my CR-V towed home, a good friend of mind was benevolent enough to come over to assist me with determining the cause of the issue. After about five minutes, he began to laugh and asked, "When was the last time you had a tune-up?" My response was, "I have never needed a tune-up."
At this point, my friend had determined that only one spark plug was firing. --"Duh!" I have always been concious of ensuring the timing belt was changed within the parameters of the Honda-mandated schedule, as well as timely oil changes per the owner's manual, brakes, tire rotations, etc. The one maintenance task I had never performed, in the eleven years (and 230,000 miles) I have had my Honda CR-V, was a tune-up.
I've always felt Americans needlessly "over-maintain" their vehicles, and that when my CR-V needed a tune-up, it would let me know. Well, it did, in a big way!
So I go online to research the best spark plugs for my Honda, and in reading comments from others who have the first-generation Honda CR-V (1997), your NGK spark plugs are the brand most-often recommended for my CR-V. Feeling confident with my research, I go to the local auto parts store and purchase four of your NGK V-Power ZFR5F-11 spark plugs.
When my friend removed the existing spark plugs, in order to install the new ones, you can't imagine my surprise to see that the eleven year-old spark plugs were ALSO NGK ZFR5F-11 plugs!! How amazing is that?!! I am keeping them for posterity!!
   / "Over-maintaining" a vehicle.... #2
I hate to think how much over maintaing goes on, all promoted by dealships.
   / "Over-maintaining" a vehicle.... #3
You have to wonder what those plugs looked like!
0.2" gap ?
For sure, there would have been nothing left of the centre electrode. Amazing he didn't kill the coil.
I find it funny that he had done other maintenance, but had a "Keep driving till it stops moving" attitude about the plugs.
Wanna bet that it's still on the original Fuel Filter ?
Rgds, D.
   / "Over-maintaining" a vehicle.... #5
Spark plugs go a long way now; I guess. Electronic ignition really reduced the need to change them out much. I'll probably never do it on this Tacoma that I have. Did it twice (probably needlessly) on the old Tacoma.
NGK were the ONLY plugs in our Fiat 124S sedan back in the 70s that wouldn't start misfiring after only about 5,000 miles. On its 1400 cc engine, one revved it a lot.
Ralph
I hate to think how much over maintain goes on, all promoted by dealships.
My choice of title was mostly a symptom of my usual sarcasm..... :)
While that is a decent plug, it is NGK's entry level plug - he ran that plug more than 4 times the mileage it should have been in the head.
What I find really ironic is this is a Honda - which most people buy to conserve fuel with. For the sake of $12 in plugs, he wasted a substantial amount of fuel.
:confused::confused::confused:
Rgds, D.
Ralph
I like NGK plugs, esp. in Japanese engines. For a similar era Civic, the factory calls for 30,000 mile plug changes (exact same NGK pn). Many people push past 30k, but 240k is nuts, and a big fuel waster.
Rgds, D.
   / "Over-maintaining" a vehicle.... #8
I just hit the 100,000 mile mark and am doing the plugs. On my Mercury Mariner you have to take the intake off. also changing coolant for the first time and trans service #3. I never did the rear brakes yet so I'll give them a peek.
   / "Over-maintaining" a vehicle.... #9
I had NKG plugs in my Evinrude 4 stroke motor and after 2 years of none issue, one spring after setting in the garage for the winter it was surging. It would crank and idle but when it was given full throttle it would only run about 2000 RPM for a while and then suddenly run normal for a while then back to no power. Sounded like a fuel problem and I changed hoses, fuel tanks to no end of problem. Finally I stopped at a marine dealer and talked to the mechanic. He knew instantly that it was the plugs. He said NKG were notorious for shorting out. I changed them out to the tune of about $8 each and it has ran fine since. I got rid of the NKG brand though.
   / "Over-maintaining" a vehicle.... #10
Common sense should be renamed. I know several people who are like that guy. If the manual says to do something they will religiously do it. However if it's not listed then either they assume it doesn't need doing or don't even know about it. I've watched air filters get thrown out simply because the manual said to replace it even though it looks brand new.
2016 FREIGHTLINER CASCADIA TANDEM AXLE 6X4 MID ROOF SLEEPER TRUCK (A51219)
2016 FREIGHTLINER...
Lot of Stihl Hedge Trimmers (A48083)
Lot of Stihl Hedge...
2017 Bomag BW90 AD-5 Vibratory Articulating Tandem Smooth Drum Roller (A50322)
2017 Bomag BW90...
2021 New Holland T9.565 HD 4WD Tractor (A50657)
2021 New Holland...
Lot of 3 Dell Desktop Computer (A48083)
Lot of 3 Dell...
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
