Once upon a time in the land of Me......
   / Once upon a time in the land of Me...... #31
You'll need to measure yours... DT vs. HST; L2800 vs. L3400, 2004 vs. 20??
What I would suggest, the top plate can be much larger than what the original top plate is. Plenty of space up there. The rear plate could be a hair larger (width and length) but watch for interference with the 3 point arms going up and down...
I might have missed it, are you welding the crack or replacing the cracked part?
The trans case is welded and tractor is back together, so I think if I get that toplink reinforcement plate on, might give it enough strength so I dont have to replace the transmission case, this winter I'll find out. I was thinking of going full 6'' wide on the plate and if length and depth is not critical, I'll just take some measurements and pick a number, then find every bolt hole I can find to bolt to. Your HST trans case might be a little different, but a L2800dt is most likely the same as a L3400.
2022 Club Car...
Vacuworx Vacuum Lifter Pad (A50860)
Vacuworx Vacuum...
John Deere 455G Loader (A48837)
John Deere 455G...
2007 Pace American Enclosed Trailer (A49461)
2007 Pace American...
Misc. Electronics (A50860)
Misc. Electronics...
Vacuworx Vacuum...
