Mowing Old L275 and brush hog
   / Old L275 and brush hog #11
Another friend with a newer L275 (maybe it's a 285??) has a shuttle on the left side of the steering wheel, clutch down-shift to reverse. That may be a early 90's model.
The one I was speaking of (80's) does not have a shuttle, and seems to be a smaller frame size. I will check if the PTO has three or four speeds. It seems to have four in an H pattern. Could the PTO have a reverse? I'll get a pic of the shift levers. Thanks all. Jim
   / Old L275 and brush hog #13
Darn iphone
Duplicate
   / Old L275 and brush hog #16
My 275 is at the farm. It is early 80's and has 3 pto speeds 540,750, &1000. Keep it at 540 and you will not hear the whistle mounted on the rubber radiator overflow hose. I can tell when it is running hot-by the smell of antifreeze, then the whistle. high and low range effects only the trans. Mower will be fine mine is a 5ft. that came new with a 8n ford.
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
UNUSED FUTURE MISC HYD HOSE BUNDLE W/ FITTINGS (A57193)
UNUSED FUTURE MISC...
PAIR OF MINI RUBBER TRACKS (A57193)
PAIR OF MINI...
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
2019 Chrysler 300 Sedan (A55853)
2019 Chrysler 300...
2008 Pierce Enforcer 61ft. Ladder Fire Truck (A55852)
2008 Pierce...
