Oil Can--Need Some Advice Please
/ Oil Can--Need Some Advice Please #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
This probably sounds like a trivial topic but so be it. I've had numerous oil cans over the years and have thrown away probably 3 out 4. Maybe I'm just picky but it seams like some are simply junk and leak like a sieve out of the top end.
My question has to do with different sizes of oilers on smaller equipment like machine tools (drills, mills etc) that have a tiny spring loaded ball type female fitting to accept oil type lubricant. (See the illustration in the lower right of the link just below) I see at least two different sizes of these fittings on my equipment. I have a couple oil cans with a ball shaped spout end that should fit these type of fittings but doesn't seem like they work worth a hoot in that they don't seal well when trying to inject oil. Perhaps the end of the spout should be a soft material like neoprene?
http://listoftools.com/images/lubrication_fittings.png
I'm not talking large oil can but something about the size shown in the link below. I see that it is a "Golden Rod" brand. I recall that brand from 50 or 60 years ago but they're probably imported now.
Amazon.com: Goldenrod Pistol Pump Oiler - 6in., Model# 606: Industrial & Scientific
Looking to hear your thoughts, facts and opinions.
/ Oil Can--Need Some Advice Please #2
I don't think they are supposed to seal. You push the ball down and just let a little dribble past it. It's an oil fitting, not a grease zert. They can be messy and the smaller the oil can, the better and easy on the trigger. good luck
The fittings are sometimes on a vertical surface and the hole extends maybe a couple inches horizontally. Would be difficult to make sure some oil is getting to where it is needed.
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
JEEP FOR DOUBLE TRAILER (A58214)
JEEP FOR DOUBLE...
Blast Off Hot Pressure Washer Trailer (A61567)
Blast Off Hot...
2007 PACE AMERICAN 14 T/A DOG HOUSE (A60736)
2007 PACE AMERICAN...
2020 MACK PINNACLE (A60736)
2020 MACK PINNACLE...
2004 Bulter Pole BP-2080-A T/A Pole Trailer (A60352)
2004 Bulter Pole...
