Occasional users: how often do you change oil?
   / Occasional users: how often do you change oil? #21
If the oil is of normal colour you don't have much water in it, is diesel engines and they are not made of porcelain. I run my tractor a few years on the engine oil, in the rear I changed it in 1988 and it's still like new. It has run 400 hours since then so I might change it some day.
On my other I run 100 hours intervals and that's ca 2,5 years.
   / Occasional users: how often do you change oil? #22
The biggest problem with water building up is that it causes oxidation to occur in the oil. When the engine warms up the water boils off but the oxidation stays
   / Occasional users: how often do you change oil? #23
It depends a lot on your climate. Big temperature swings are the worst.
I never figured out why they (always) say to change oil more often in dusty conditions. Not like engines are run without an air filter.
   / Occasional users: how often do you change oil? #24
The problem with oil analysis is the cost. Blackstone charges $28 and it can be cheaper to just change the oil
Exactly!! These UOA are worthless for someone with 1 or 2 units, it's cheaper to do the Oil change than the analysis or pretty close to it. UOA are worth it for someone using machines with same oil & type of work then with 1 UOA you can determine the state of all the others.
   / Occasional users: how often do you change oil? #25
As I understand (rightly or wrongly), most moisture and un-burnt fuel in the engine block gets evaporated and vented (or goes to intake) when engine comes up to operating temperature.
Actually as it was explained to me this is not enough. The engine must come up to operating temperature and the Worked for about 30 min for all moisture and fuel to be burnt off
   / Occasional users: how often do you change oil? #26
I agree. My Corvette water temp comes up after a few miles but it takes a lot longer for the oil temp to come up.
You can get a UOA kit from Wix for under $10 if you buy it from Rock Auto. That's less than a gallon of Rotella and would be interesting. I just might do one on the oil that's in my tractor now and post the results here.
   / Occasional users: how often do you change oil? #28
Well that is the answer for the OP. With oil analysis, he may discover there痴 nothing wrong with going 3+ years on a low hour machine. My manual doesn稚 even mention any change based on anything other then hours used so if an owner is going to change based on something else he is in uncharted territory without an analysis.
Regardless itç—´ your money, do what you want.
I put about 10-15 hours each year on my tractors.
I change oil every 2 or three years.
My tractors would likely be just fine if I never changed the oil.
Both my tractors, and I, are too old for me to be concerned with oil change frequency.
   / Occasional users: how often do you change oil? #29
Normally every year isn't a problem for my 200hr intervals.
But my opinion: if when you normally operate the tractor, you are working it long enough to get everything up to operating temp....I have non-issue going 2 or 3 years. My backhoe is a good example of this. Maybe 30-50 hours a year....but when I do use it....it's for 3+hours at a time.
Now if you make a habit of just firing it up long enough to take trash out, or bring a bucket load of wood to the shop....and more times than not you aren't getting it up to temp....then I'd do it yearly and be done
   / Occasional users: how often do you change oil? #30
This subject is discussed ALL THE TIME on many forums....but that's ok.
My 2 cents are: Once oil/lube is removed from its sealed drum or gallon jub and is placed into service - such as into a crankcase, tank rearend housing, etc. it is being exposed to oxidation and evaporating. Any crankcase has a vent to the atmosphere which typically allows for any offgasing when heated & cooled from operation. This also allows for moisture to enter and for portions of the oil/lube mixture to vaporize off. I am confident there are many times (epecially in the winter) that these lube systems do not get up to temp to clear out any moisture/condensation collect inside. So in considering this fact, regardless of hours ran, I believe it is prudent to change the motor oil & filter at least annually.
Some folks desire to follow the Operator's Manual to the letter. Fine - that's their decision. But I realize that these same manuals are very generalized - only varying between 'cold operation' and 'warm operation'. Secondly, as these vehicles/manuals age, they don't update as newer lubricates become available. My Granddad always told me, "Don't worry about what type of oil or when it was last changed, but just make sure it HAS OIL IN IT." In other words, what is important is to NOT operate it a quart or two low where it may overheat or suck air into the system.....
Rearend lubes, powersteering fluid, hydraulic fluid, etc. less often. If it's simple (like an external, spin-on fitler) I usually try to change the hydraulic filter annually, but only top off the hydraulic fluid. I try to bled brake systems annually, (and I recently will add hydraulic clutches to this annual bleeding). I test the pH of my coolants to track their acidity (keep above 8+pH). Grease stuff at least quarterly or as use dictates..... That's my 2 cents. Please carry on with other opinions.... :thumbsup:
BarnieTrk
2012 HYUNDAI  HL740-9 WHEEL LOADER (A58216)
2012 HYUNDAI...
2004 Chevrolet C5500 Flatbed Service Truck with crane, VIN # 1GBE5C1214F513547 (A57453)
2004 Chevrolet...
Heavy Duty 44in Excavator Rake (Fits CAT 305) (New/Unused) (A59225)
Heavy Duty 44in...
Sheets of Tin (A57149)
Sellick S60 Forklift (A57148)
Sellick S60...
2007 John Deere 6215 (A57148)
2007 John Deere...
