Not the clutch!
   / Not the clutch! #1
DonnSr
YM 1700 Yanmar
Jumped on the old Yanmar, it’s been a while, and the clutch would not disengage to shift. Figured stuck clutch, ran it around trying to unstick it but no luck. Clutch pedal felt very easy? Decided to just get a new clutch kit and fix a few other leaks while I have it down. Pulled the motor, removed the clutch and it did look like it had been stuck but a lot of left over meat on the disk. Installed the clutch kit put the motor back in but the clutch pedal feels the same, I can push it down with my hand with ease? Checked all the linkage and pins were in tack and all looked good. Put it in the air and was able to turn the tires in neutral, stopped in gear, pushed in the clutch still couldn’t turn the wheels? Seems to me nothing changed? That easy clutch pedal worries me even after adjusting. Any ideas or checks that can locate the issue? Thanks!
   / Not the clutch! #2
Sounds like something is going on that is preventing the linkage from the clutch pedal fully engaging the clutch fingers via the throw out bearing.
Not familiar with the Yanmar setup but typically there is some sort of adjustment in the linkage that is used to get full clutch engagement and full clutch release.
   / Not the clutch! #3
This is a "suddenly appeared" problem? You split the tractor, replaced clutch disc AND pressure plate? (Clutch "kit" usually includes both as well as both bearings)
The old pressure plate did not appear to be broken or damaged to speak of? Now it still has the same "feel" and same problem?
Next time you split it pay more attention to the cross shaft, release fork, and the connection between the two.
   / Not the clutch! #4
I was going to say "check slave and master cylinders", but that comes from working on a lot more cars than tractors. :ROFLMAO:
There's no view port in the bellhousing, where someone can see if the fork is actually moving the throwout bearing?
   / Not the clutch!
Clutch disk had a lot of material on it still but you can see where it was sticking on the flywheel and pressure plate. When removing pressure plate it seemed worn out, it didn’t have much pressure on it when removed. Replaced with kit including pilot bearing. Mechanical clutch so linkage and checked fork, all straight forward and looks fine. It’s not completely back together so if I had to split it again no issue.
If I can’t turn the wheels when in gear I should be able to push the clutch in and spin them. I can spin the wheels in neutral.
I’m thinking I need to split it again and check all the clearances again unless I’m missing something?
   / Not the clutch!
You’re right, I’m overthinking because I really don’t want to split the case again but it’s mechanical linkage, it’s straight forward, just need to take all the measurements. Thanks for the reply!
   / Not the clutch! #7
With mechanical linkage, I would typically adjust so there is maybe 1-1/2” to 2” free play in the clutch pedal before the throughout bearing engages the pressure plate fingers. Not sure the service manual would provide this info.
   / Not the clutch! #8
Tell us about the throwout bearing. Did the kit come with one? what was the shape of the old one? Is the fork engaging the TO bearing correctly?
   / Not the clutch!
I’ve attached some measurements that hopefully make sense. Compared parts to those removed and are the same. The parts removed showed no signs of damage for the exception of the thin layer of clutch disc material stuck to flywheel and pressure plate. Kit came with pressure plate, disc, throw out bearing, and pilot bearing.
The clutch not disengaging was the original problem. Clutch pedal went right down and never felt any resistance. Adjustments to linkage did not work. Split the case again and took these measurements which to me tells the story why the clutch does not work but not how this could happen. According to these measurements the throw out bearing is not touching fingers of pressure plate with clutch pedal all the way down? I measure 3 and 4 times and always the same.
   / Not the clutch! #10
How does the fork fasten to the cross shaft? Pinch bolt with a dimple in the shaft? Keyway with key stock? Roll pin (hope not)? If you can't get enough adjustment using the pedal free play adjustment to get the clutch to release properly (and the problem was present with the previous clutch) I'm still betting the issue is between the cross shaft and the fork.
2017 TRAILSTAR END DUMP TRAILER (A50854)
2017 TRAILSTAR END...
2012 Tiger 130BBL Vacuum Trailer (A50860)
2012 Tiger 130BBL...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
Pallets and Boxes of Miscellaneous Car Parts and Supplies (A48083)
Pallets and Boxes...
UNUSED Collapsible Cart and Foldable Table (A50860)
UNUSED Collapsible...
2020 Case IH 8250 4WD Combine (A50657)
2020 Case IH 8250...
