Nord-lock, Heico-Lock, Belleville LOCK WASHERS; Spiralock LOCK NUTS --- Any Good?
   / Nord-lock, Heico-Lock, Belleville LOCK WASHERS; Spiralock LOCK NUTS --- Any Good? #1
jeff9366
Super Star Member
Alachua County, North-Central Florida
Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
I am seeking a way to keep four X 1" axle nuts tight on my factory-new Howse disc harrow.
I do not weld. I am considering Loc-Tite.
I would prefer to replace factory low-tech split-ring lock washers with some improved nut-locking hardware.
What about specialty lock washers? NORD-LOCK, BELLEVILLE, HEICO WEDGE LOCK.....others?
What about SPIRALOCK lock nuts? .....others?
Are any of these particularly suited for maintaining axle nuts TIGHT on a disc?
LINKS:
10 1" 25mm Nord Lock Vibration Proof Lock Washer | eBay
Fractional Hex Flange Nuts | Emhart Americas
   / Nord-lock, Heico-Lock, Belleville LOCK WASHERS; Spiralock LOCK NUTS --- Any Good? #2
Loctite is hard to beat if the fasteners are clean and Loctite primer is used.
   / Nord-lock, Heico-Lock, Belleville LOCK WASHERS; Spiralock LOCK NUTS --- Any Good? #3
Most discs I have seen have a shaft with a keyway or flat on them, a nut and a piece of metal behind the nut that bends up to loc the flats of the nut in place.
Aaron Z
Not the Howse DLHT 16822 16/18. Nut and spring split lock washer only.
I am aware of established hardware.
I am seeking information on improved locking technology: Nord-lock, Belleville, Heico Wedge Lock and others.
   / Nord-lock, Heico-Lock, Belleville LOCK WASHERS; Spiralock LOCK NUTS --- Any Good? #5
I know what aczlan is talking about. You could do this with a flat washer and a cold chisel if you wanted.
   / Nord-lock, Heico-Lock, Belleville LOCK WASHERS; Spiralock LOCK NUTS --- Any Good? #6
If the shaft isn't keyed (ie: a round shaft), I might get a castle nut in the right size and drill the end of the shaft for a cotter pin.
Aaron Z
Gentlemen:
In this thread I am interested in STATE-OF-THE-ART.
I am seeking input on Nord-lock, Belleville, Heico Wedge Lock and other state-of-the-are bolt locking technologies.
   / Nord-lock, Heico-Lock, Belleville LOCK WASHERS; Spiralock LOCK NUTS --- Any Good? #8
This stuff isn't state of the art. These have been around for a good while.
Nord-lock- We use these at work. We call these serrated washers. For light duty applications.
Spiralock- These are pre-scored bolts and nuts. You can make these with a hammer and a sharp punch
Heico-Lock- Another variety of serrated washer.
None of these would I use on a heavy duty application like the axle nut on my disk.
   / Nord-lock, Heico-Lock, Belleville LOCK WASHERS; Spiralock LOCK NUTS --- Any Good? #9
Any chance you could get two nuts onto the axle?:)
   / Nord-lock, Heico-Lock, Belleville LOCK WASHERS; Spiralock LOCK NUTS --- Any Good? #10
Given the parameters, probably the best solution here.
If the disc spools are worn from running loose, nothing will work successfully.
Clean mating surfaces across the gang and proper nut torque are steps 1 and 2.
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
2015 GENIE ZX-135 / 70 ARTICULATING MAN LIFT (A52709)
2015 GENIE ZX-135...
2020 CAT 272D3 Wheeled Skid Steer (A59213)
2020 CAT 272D3...
2018 Ford F-350 (A55973)
2018 Ford F-350...
2003 PETERBUILT PB330 DUMP TRUCK (A58375)
2003 PETERBUILT...
2013 Ford Transit Connect Cargo Van (A56858)
2013 Ford Transit...
