No more plastic drain valve for me!
   / No more plastic drain valve for me!
LBrown59 said:
How did you ever get that elbow in there ?
It's all in the first post of this thread (unbolt and lift the engine). I was able to lift my engine JUST enough to install the short nipple and elbow into the engine block & still clear the frame. The driveshaft was hitting the top of the tunnel. It's an easy mod and only a few dollars of pipe fittings. Add another $20 or so if you want a fumoto drain valve on the end. I don't see how using copper would make the job any easier. You still have to lift the engine to get the 'factory' quick drain out of the block.
Joel
   / No more plastic drain valve for me! #22
TractorLarry said:
That's similar to what my 1864 has from the factory.
Nice job!
Make a kit. Sell it :)
Bandaid's included!
-Larry
It would have been simpler to install it before the motor was installed on the tractor.
   / No more plastic drain valve for me! #23
Joel
I was thinking with sweated copper fittings you wouldn't have to rotate the elbow;but you're rite removal of the quick drain still presents a problem.
   / No more plastic drain valve for me! #24
My 2554 has a similar setup from the factory. They use a shorter nipple from the elbow to the drain valve and still use the plastic drain valve.
JT's setup is nicer. Higher quality parts and even easier access.
LOT: (1) Craftsman Shop Vac, (1) Dewalt Shop Vac (A59076)
LOT: (1) Craftsman...
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
Leer Camper Shell (A57454)
Leer Camper Shell...
2008 HINO 26FT NON CDL BOX TRUCK (A59575)
2008 HINO 26FT NON...
2014 International Maxxforce DT (A53317)
2014 International...
2015 Dodge Charger Passenger Car, VIN # 2C3CDXAT4FH817483 (A57453)
2015 Dodge Charger...
