NH TN 65 - Looking to buy - looking 4 input good/bad
   / NH TN 65 - Looking to buy - looking 4 input good/bad #21
Roper14 said:
That was one question I asked about the TN 65 (and may or may not have gotten the "right" answer) because I have been around a TL 90 before ( a totally different tractor hence the reason for asking about the TN's) yet it too was also a little light in the back end when we would pick up hay...ended up having to fill up the back tires.....yet I was told "never had a problem" with the TN so they may had never picked up anything really "heavy" or it truely did not have any problems----- the way I look at it, I can get by with that if that is the only issue with the tractor....(put anything on the back end - or put water/antifreeze in tires)..........thx for the input on the tractors and $ range
Depending on how much weight your are picking up you will need rear weight on the TN. I have my rear tires filled and if I am picking up something heavy (2500 pound pallet of shingles or such) I put the box blade on the back and hang suitcase weights off of it for more weight. Makes things nice and stable. If I am just moving dirt the weight from the rear tires is plenty.
   / NH TN 65 - Looking to buy - looking 4 input good/bad #22
I've had 2 TN's, a TN75S and now a TN75D. They are both great tractors although I have had a few problems which the dealer corrected with out issues. I've had the latest once for 5 years ow and it runs fine. As far as heavy loader work, I have loaded 16x9- R30's and still need a rear implement to keep the rea end on the ground.
Andy
   / NH TN 65 - Looking to buy - looking 4 input good/bad #23
If you do a search on TN on this forum every post you find is something positive. There's a few niggling problems here and there but no major issues.
It was a major factor in me buying my TN.
And BTW, I bought my TN sight unseen. I'd never driven one, been in one, even seen one and it showed up one day on a truck 2.5 months after I ordered it and wrote a check for 42,000 dollars.
And, like all the rest, it's been problem free, it's comfortable and it's strong.
I think the TN is one of the best tractors made of any make.
   / NH TN 65 - Looking to buy - looking 4 input good/bad #24
Speaking of weights...I ordered front weights for my 75 but it was delivered w/o them (wrong bracket ordered). I ran it w/ a std duty 8' mower until the bracket came and even w/ the bigger axle/tires/wheels up front there were places I didnt go b/c it was too light. The front weights were necessary to balance the mower.
   / NH TN 65 - Looking to buy - looking 4 input good/bad #25
With a loader you don't need the extra front weights though.
   / NH TN 65 - Looking to buy - looking 4 input good/bad #26
:) right forgot he was getting a loader...if you remove the loader then you may still need weights. :)
   / NH TN 65 - Looking to buy - looking 4 input good/bad #27
I leave my FEL on 99% of the time on my wet land, it allows me to curl my way out of really soft ground that stops me. Has saved me from having to call a neighbor to get towed out.
Bob
   / NH TN 65 - Looking to buy - looking 4 input good/bad #28
WOW! Youare my hero!
Bob
PS I love my TN. It is a brute.
   / NH TN 65 - Looking to buy - looking 4 input good/bad #29
Hi Roper14! I am the proud owner of a TN65D for three years and its the best tractor I ever owned. (I have owned 6 other tractors) The only difference between the one you are looking at and mine is that I have 4 wd and a cab. The tractor will mow all day on a tank of fuel, pull a 13 foot disc, or a 3 bottom plow. Its loader is strong ,well built and easy to take off or put on. I highly recommend the tractor. Good luck on your negotiations on the price. Ken
   / NH TN 65 - Looking to buy - looking 4 input good/bad #30
Bob
Yup, I can understand that but Ive run into cases when its really in the way esp when getting up close to fences and such. In general any case when having a chunk hanging out front isnt desirable.
2006 BOMAG BW5AS DOUBLE DRUM COMPACTOR (A51242)
2006 BOMAG BW5AS...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2016 Ford Escape SE AWD SUV (A50324)
2016 Ford Escape...
2018 JOHN DEERE 310SL HL BACKHOE (A51242)
2018 JOHN DEERE...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
