NH TC40D rear hydraulics
   / NH TC40D rear hydraulics #1
RobertN
Super Member
Shingle Springs California
New Holland TC40D
I have a NH TC40D. It does not have rear remotes for tip/tilt, or auxiliary lines to run a log splitter.
The factory parts are discontinued.
I have not been able to fin any aftermarket support that would bolt in like the factory valves and pipe did. I don't see anything from Shibuara.
Are there any options besides bolting an aftermarket valve set to the ROPS and tapping in to the Power Beyond on the loader valve?
I wish I would have done it when I got the tractor; parts were available... Jinman(miss him!) had the whole factory setup on his TC45; that was a nice setup.
   / NH TC40D rear hydraulics #3
Looks like parts are readly avaible and pretty cheap to 1st is $550 2nd $550 3rd is $1100 . The only reason I don't buy them for my tractor is they are $1,400 and $1,200 respectively.:eek::thumbdown::drink:
I had not tried Messicks. Where I had found the remotes online, they all said not in stock/not available.
Looking at Messiks now
This opens up more questions. I am really looking for two things.
#1 I have a 3pt log splitter that runs on tractor hydraulics. Right now, it has long hydraulic lines; I disconnect hydraulics from the load and plug the splitter in. Then I engage the loader lever to supply splitter. Works, but not good solution when I want to move etc.
#2 I would like to add TnT at some point. I had it on my old Kubota, and really miss it.
To use the log splitter, would it be best to use a remote valve kit, and connect the splitter to it in place of a TnT top or side link? These valves do not stay open; I'd have to bungee cord the lever? Effectively that is what I am doing with the loader hydraulic circuit now. It would still be nicer to not have to use the loader circuit.
   / NH TC40D rear hydraulics #6
Fab a mount for an aftermarket valve stack with three valves, one of which has detent for the spitter. You also might want float for the top link valve.
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A51039)
NEW 2022 Load...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
2019 Generac MLTS-1 2.4kW Towable Light Tower (A49461)
2019 Generac...
2012 Ford F-550 Bucket Truck (A49461)
2012 Ford F-550...
2014 John Deere 8360R MFWD Tractor (A50657)
2014 John Deere...
Blue Concrete Test Shed (A49461)
Blue Concrete Test...
