New to welding.....having a blast w/projects!!
   / New to welding.....having a blast w/projects!! #21
Listen to this guy he knows his stuff.I've been welding for years and thought i knew what i was doing .Well my stepson just got out of metal fabricating schhool and i quickly found out i did not know as much as i thought.My welding looks real good but i must of fell asleep when the theory part was going on in high school.lol
Tdog
   / New to welding.....having a blast w/projects!! #22
I know a tiny little bit but there is so much to know about welding and filler metals that there is nobody on the planet that knows everything. One thing I forgot to mention is that NR 211 is an E71T-11 wire and is designed for single or multi-pass welding. There is another similar wire, that I don't even know why they make it, E71T-GS. It is sold just about everywhere but is only designed for single pass welding which further limits what you can use it on. Lincoln has some special purpose Innershield wires for single pass welding but they aren't just sitting on the shelf for anyone to buy like the GS wire. I'm not sure what the GS stands for but in my opinion it could stand for gullible souls or generally _hitty. Maybe for thin material and galvanized steel that only needs 1 pass it's OK but for a general purpose wire, the T-11 would be a better all around choice in my opinion. Unless of course you needed a wire for welds under a lot of stress. Then you'd want T-8 Innershield wire but they can be quite expensive. This brings into play why it's good to have a wire feed welder that can also run shielding gas. With shielding gas you have the option to run solid wire MIG or Dual-shield which are both designed for welds under stress but a lot less expensive to buy than the T-8 self shielding wires.
   / New to welding.....having a blast w/projects!! #23
Before the Northridge earthquake in California we used Hobart's Fabshield 21-B. I never used anything smaller than .045. Not sure if I ever tested with .068 or not. Have no idea how many 1-inch side bend tests I took with 5/64-inch 21-B. It's one of the best all around general purpose wires I've used.
The Northridge earthquake stood the structural welding world on it's ear here on the west coast. Now about all you see is Lincoln's NR-232, NR-233, or ESAB's Coreshield 8, all T-8 wires. Right in the WPS it calls for CV only machines.
1991 Suzuki LT160 Quad Runner (A59814)
1991 Suzuki LT160...
UNUSED JCT 72" HYD 4N1 BUCKET (A52706)
UNUSED JCT 72" HYD...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
JOHN DEERE 744L WHEEL LOADER (A60429)
JOHN DEERE 744L...
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
