Hi all,
Been lurking on here for a couple years but finally have a reason to post! We recently purchased a new home on 20 acres and I was able to work a deal on a couple new "toys". One of which is the 1070. This thing is a cream puff. it's a '93 and had 280 hours on it when I took possession in September. She now has 304 due to some heavy fall cleanup. All in all it's like a brand new tractor. It has an 80 series loader, 506 rotary cutter and a beat up box scraper that I need to rehab. I've spent some time going over it and while the previous owner took very good care of his stuff there were still some things that needed to be done. Here is what I have done already (or plan to do over the next week or so) and I'd like to hear from others if there is anything else I should do. Here is the process:
- Washed down the entire tractor and coated everything with Fluid Film
- Cleaned the engine, removed all debris from radiator and around the shrouds
- Changed oil and replaced with Wix filters/Amsoil 15W-40 Diesel Syn
- Drained and replaced gear oil in front diff w/ Amsoil 75W-140 Syn gear lube
- Drained hydraulic/tranny system, replaced with Wix filter and Amsoil Syn Hydro fluid
- Drained/flushed cooling system, replaced with Amsoil antifreeze and distilled water 50-50 mix
- Replaced inner/outer air filter with Wix filters
- Replaced fuel and fuel/water separator filters
- Greased all points with Amsoil Molly HD grease
- Treated diesel tank with SeaFoam
So far that's been the protocol. Let me know if I missed anything. Thanks all and I look forward to being quite active on here. My next post will feature my newly installed WR Long hydraulic plow to take care of the 1/4 mile drive
Cheers,
Don
Cheers,
Don
