New problem with our HST
   / New problem with our HST #1
Qapla
Veteran Member
Gator Country
New Holland TC40D HST 4WD FEL/BH
We have a NH TC40D with a FEL and BH.
Using it today I found a new problem ... I was trying to dig out a stump and when I positioned the tractor I discovered that the FEL will no longer lift the front off the ground. Even using the "tilt", it would not lift the front off the ground - it used to.
Also, when I had to drive out into the field quite a distance, I used Range II like I usually do. When I started, I was in "turtle", then I hit the button for "rabbit" and the machine bogged and almost died.
Later, we had a hose break and, when we brought the tractor over to take the hose off, we checked the hydro fluid dipstick. It did not show - the tractor was running.
Should we check the fluid with the tractor running or off? Also, would low fluid cause these other problems?
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
LOT LOCATIONS (A51222)
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
19008 (A48082)
19008 (A48082)
