Oil & Fuel New Member who is stumped! GC2300
   / New Member who is stumped! GC2300 #11
good luck on the mission i hope the fix is inexpensive and easy
   / New Member who is stumped! GC2300 #12
This is a famous phrase said by Polonius in Act-I, Scene-III of William Shakespeare's play, Hamlet. The character Polonius counsels his son Laertes before he embarks on his visit to Paris. He says, 哲either a borrower nor a lender be; For loan oft loses both itself and friend.納/QUOTE]
Thanks for the quote. I have never heard the second part.
   / New Member who is stumped! GC2300 #13
It can only be fuel or air. Drain the tank, change the fuel filter, and fill the fuel filter to the top with transmission fluid. Pour the rest in the tank. Make double sure your intake is free of obstruction. If this doesn't help, run a compression test.
   / New Member who is stumped! GC2300 #14
Jimmy,
Why would you want to fill the fuel filter with transmission fluid? That is a new one to me that I have not heard.
   / New Member who is stumped! GC2300 #15
It adds lubrication to the injector pump and injectors. The fuel system relies solely on the fuel itself for lubrication of moving parts. I've run a tractor off straight transmission fluid before. It doesn't hurt it.
Transmission fluid has detergents and lubrication properties that clean injectors, valves and combustion chambers.
The only time it is unsafe to do this is if you have fancy emissions system. I've never done this on a common rail set-up either.
If you don't like this idea, use marvel mystery oil.
   / New Member who is stumped! GC2300 #16
I'm a little surprised no one has asked or answered a couple other questions?
Running at startup implies fuel and ignition systems are OK because by now any fuel has moved from tank to fuel filter.
But black smoke late after running could imply load on the engine and/or overheating. So here are my 2 questions:
1. Is it possible either pto lever or brake is engaged thus luging the engine?
2. Is your temperature gauge higher than normal?
The list of people other than myself that have ever driven my tractor in 3 years is 2; sales person who delivered and demonstrated it's use at delivery. The second one is a very good friend who has a tractor and he test drove it at my home with me right there.
My point is that tractors are a far greater liability risk than a lawn tractor or a skid steer. In addition, no insurance covers borrowed equipment off-site except a special commercial or rentail policy (not any umbrella policy either).
Terms & Conditions of (Buying through EquipmentDealz Auction) Final (A59213)
Terms & Conditions...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58216)
HYDRAULIC THUMB...
2022 New Holland C327 Compact Track Loader (A56438)
2022 New Holland...
2287 (A58376)
2287 (A58376)
Generac Power Systems (A57148)
Generac Power...
