New member / injector
   / New member / injector #11
Welcome.
So why do you think it's the injectors? These are usually re-buildable, at least in the states. I would take them apart and clean them before buying new ones. Jut keep track of how you took them apart. There are shims inside that set the open pressure, so you need to get those back in right. But worth looking at before you spend the money.
Take the injectors out and pull the lines. Take the lines and turn them so the face away from the engine and install the injectors and see what the spray patterns looks like. This will show you what the injectors and pump is doing.
From jdparts, the injector nozzle part no. looks to be AM877675, on Amazon for $180 USD
Schematic looks like this.. hopefully will help you find what you need.
Hi Again beenthere, do you perhaps have the part number for the seal that fits on the end of the injector?
Many thanks
   / New member / injector #13
Claud
If you are referring to key # 41, then that seal part # shows as M801016
Also, you can find these parts by going into jdparts.com and putting in your model 955.
John Deere - Parts Catalog
Hope this helps.
   / New member / injector #14
Injector is a little cheaper from JD dealer than Amazon. AM877675 F.I. NOZZLE ASSEMBLY ADD 163.75*USD
Thank you Beenthere & Jim, I appreciate the help and information. Found a new set of injectors from wengers at $125 each.
   / New member / injector #16
NORMALLY, you can get YOURS REBUILT for alittle over 1/2 that..at a fuel shop.
IF you were in the States, I know I could beat that.. but the shipping costs would probably eat any savings you would get.
RED-D ARC INC.WELDERENTALS DC600 CV/CC ARC WELDER (A57192)
RED-D ARC...
2017 Ford F150 (A55973)
2017 Ford F150...
2012 PETERBILT 388 WINCH TRUCKS (A58214)
2012 PETERBILT 388...
2007 Ford F750 (A55973)
2007 Ford F750...
UNUSED WOLVERINE SBG-13 72W 83.2" SLIDING (A57193)
UNUSED WOLVERINE...
CATERPILLAR 302.7CR EXCAVATOR (A52707)
CATERPILLAR...
