New Kuhns hay grapple earned its keep
   / New Kuhns hay grapple earned its keep #1
powerscol
SW Colorado
CT 235
Moved 252 bales of hay yesterday with my grabber unit, my 23' PJ GN trailer and a lot of luck. The tractor lifts and pulled the trailer easily in mid range. Only had a short distance to go, but handling was fine. NO HAND WORK. Once I got the hang of it I was able to load and unload and re-stack pretty well. Only problem was calibrating my depth perception:eek::D:thumbsup:
I have the 205 model found here Grabber | Kuhns Mfg LLC
Took about 4 hours from start to finish and just as I got the tarp secured it started to rain. This was one of my better decisions
   / New Kuhns hay grapple earned its keep #2
Very, very nice. Saved you time and kept your hay dry just in time.
Also save my back and that it even better:thumbsup::D
   / New Kuhns hay grapple earned its keep #4
We have a 510f grabber and although it is less labor, you are still handling individual bales. If you drop a bale it gets old real quick getting down off the tractor. Do you have a place set up to get your tractor into to unload the hay? That was the biggest challenge we had.
   / New Kuhns hay grapple earned its keep #5
Very nice.
I assume you have 1 maybe 2 more cuts for the year?
   / New Kuhns hay grapple earned its keep #6
It is so amazing to think of the progress over the years. I recall countless fields like that, bucking one bale at a time onto the flatbed. I mostly do round bales, but seeing those fields sure brings back memories.
I probably will get one more cutting this fall when we run out of irrigation water. As for a place to unload without having to do the hand work, yes. I am building a 20 foot addition to my barn with a clear span so I can maneuver the tractor. The width fits the grapple perfectly
I added a spring loaded hose holder today to keep the hoses from rubbing on the QA adapter. Should work well.
Also last week I got softhearted and helped a neighbor out at no cost to move another 180 bales. The poor kids were dieing in the heat. When I showed up and stacked 4 bales on the trailer without them touching them the look on their face was priceless. They surprised me with a gift card to TSC.
   / New Kuhns hay grapple earned its keep #9
Sir, could you reveal how much that grapple set you back financially ? I am in the market for something similar and have no idea what they cost ? My Backhoe can handle 2000lb but would prefer not to push things too far since the property I am on has some serious hills...
WOW:eek::eek::confused2::thumbsup::D calling me Sir :thumbsup: Thank You :cool2:
Contact information is John Byler [mailto:john@kuhnsmfg.com]
Please give John a call 877 296-5851 as prices probably have changed. For my unit I think the price was 3K (special order) with 12 hooks, but that was last year. It was well worth what I paid and probably more. The competition was $$$$ more and I have posted the responses I got, or lack of it before.
Excellent build quality and great service. To me with my bad back this unit is Priceless. I used it today to move a brush pile (took off the side bar) Worked great.
Please look at their matching systems - accumulator and grapple. ( www.kuhnsmfg.com ) There are other systems out there, but for my needs and their willingness to do a custom unit - which I did not need other than extra hooks on a stock unit, once the numbers on the weight panned out, They have a great selection on units to fit your needs, and that is key, as they want to fit your needs. Follow up customer service cant be be better either.
I am old school - and you pay for what you get, and these folks are honest and responsive. In talking with John and others at Kuhns, they wanted to be sure the unit I got fit my tractor specifications and MY needs and his advice was very correct.
How often do you get to talk to the engineer designing the unit? With these folks I did. I have a perfect fit for my tractor and operation. And no I don't get anything for saying this - just a great company and operation. Call their competition and see what response and pricing you get, you will be back talking with John.
Nuff said!
Hope this helps - Keith
Dewalt DWM120 5" Deep Cut Variable Speed Portable Band Saw (A59076)
Dewalt DWM120 5"...
SD Lanch SDLGC80 Electric Golf Cart (A57149)
SD Lanch SDLGC80...
500 Gallon Fuel Tank (A57149)
500 Gallon Fuel...
LOT: (2) Dewalt Electric Drills, (1) Dewalt Electric Grinder, (1) Milwaukee Grinder (A59076)
LOT: (2) Dewalt...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A56858)
2007 Western Star...
Magnum 4000 Series Hot Water Pressure Washer (A55272)
Magnum 4000 Series...
