New Kubota B3200TLB Weight
   / New Kubota B3200TLB Weight #1
devildog1
Veteran Member
Up-State New York
Grand L 3540 HST-3, R4's
:)My new B3200 TLB was delivered about five days ago and I do say that I believe this is the perfect size tractor for my needs and projects.After I put a coat of Mother's wax on everything, including the rims.:D I was reading through the operating manuals and checking spects on loader and backhoe operations. There are spects for everything, lifting, breakout, ect, ect, but what I could not find and wondered if any of the new B3200 owners knew was,--------"what is the combined weight of tractor, loader, and backhoe"? The reason I need this is if I need to trailer this tractor the weight would be very helpful on deciding which size trailer to use or borrow. I have no issues with my tow vehicle, as It's a PSD, and it will tow anything:rolleyes:
Thanks all.
Devildog
   / New Kubota B3200TLB Weight #2
Look on Kubota.com it should list the weight there.
   / New Kubota B3200TLB Weight #3
Did you get all the individual manuals for all your implements. They should have the weights of the seperate implements and then you can add it all up. I am not sure about the tractor weight if it is full of fluids or not. This is how I was able to come up with a total weight for my tractor with attachments. If you don't have all the seperate manuals and assembly manuals you should be able to get them from your dealer. They should have came with the tractor.
Well I thought I had all the weights in the manuals. I have a weight for everything but the Backhoe main assembly. It lists the weights of the different size buckets for the backhoe, but I didn't see a weight for the entire BH.
Medicshawn and jbrier,
See thats the issue, total weights are not listed in individual manuals. And even @ Kubota.com the pdf files do not have a totlal weight for tractor, loader and backhoe all together. Maybe someone will come across weights and post them.I know Kubata.com has weights for the B21 TLB and the B26 TLB's, their weight is aver 4000 lbs. So----------myself not being a math major figured the B3200 should weigh 500 lbs. to 1000 lbs. more then the B21 7 B26 TLB's. Could that be right?
   / New Kubota B3200TLB Weight #5
I don't think it'll weigh what the dedicated TLB's weigh. I'm just kinda guessing but I'd think it would come in around 3500 lbs. considering it doesn't have loaded tires or something else that would factor in.
   / New Kubota B3200TLB Weight #6
:)what is the combined weight of tractor, loader, and backhoe"? The reason I need this is if I need to trailer this tractor the weight would be very helpful on deciding which size trailer to use or borrow. I have no issues with my tow vehicle, as It's a PSD, and it will tow anything:rolleyes:
Thanks all.
Devildog
I just rounded up using 1500 for the 3200, 1000 for backhoe and 1000 for FEL, add in the thumb, subframe kit and loaded tires I went with 4000# plus. For mine I wouldn't go under a 7000# trailer with brakes. Measuring my unit with the hoe down touching the floor to the tip of the loader it measures 17 feet so 16 minimum to 18 ideal length. Allowing 1800# for the trailer depending on the deck (steel vs. wood) this should allow 1500 to 1700# for anything I missed.
Chris, Thanks for your round-up on weights. I believe your pretty much on with with a 7000 lb trailer. I just found the weight of the B3200 without FEL and backhoe, 1800 lbs. I had rim-guard put in rears @ 100 per tire. that is 2000 lb. Plus, add 1000 lb to 1200 lb for FEL and backhoe,= 4000 to 4200 lbs. I forgot to add weight of subframe, which I have no idea of weight, but It's quite a chunk of steel. Add a 60" bucket up front and a 16" bucket on back. So It should weigh in between 4200 lbs and 4500lbs, and the 7000 lb trailer will work just fine.
Rick
   / New Kubota B3200TLB Weight #8
If you figure on around 500 lbs for the FEL, and 1000 for the backhoe, you should be covered. I think the backhoe is less than 1000, but that's what I've been going with to figure my machine's weight, based on a bunch of research I did back when I purchased.
Figure around 3500-3700 lbs for your machine. The B26 is around 500-600 lbs heavier.
2017 Ford Explorer (A56859)
2017 Ford Explorer...
DeWalt Pressure Washer (A56469)
DeWalt Pressure...
Kubota KXO40-4 (A53317)
Kubota KXO40-4...
2007 Ford E350 (A55973)
2007 Ford E350...
UNUSED FUTURE DIE-CAST TOY (A57192)
UNUSED FUTURE...
Honda Pioneer SXS700 4X4 Utility Cart (A55758)
Honda Pioneer...
