New Kioti Leaking Oil.
   / New Kioti Leaking Oil. #31
So, what was the problem?
   / New Kioti Leaking Oil. #32
This is probably why Bobcat decided to centrally assemble all their white Kiotis and ship them whole to their dealers. If Bobcat had a white CX2510 I would have bought it. They don't so I have an orange Kioti that was assembled by the dealer I bought it from.
   / New Kioti Leaking Oil. #33
Sailorman3, Hailing from a PAB family, I get it. You spent the cash or signed the note and received a series of headaches....new Kioti CK3510 that leaks, garage floor full of UDT, no extra, expensive UDT stored in the garage to fill it back up, and you probably have a list of projects & task that you want to use it for. I get it...you wanted a new tractor and got multiple headaches....hassles before the first payment.
I don't know if this is a Dealer, Transportation or Factory OEM problem, but please coordinate with your Dealer for the fix. I would NOT put a wrench to it. It may be a fitting or seal a Kioti tech could fix in minutes. Absolutely do not put a wrench too it while under pressure.
Be happy it's ONLY an external line, probably a remote as you mentioned, maybe a bad hose. You could get out the baby powder and try to find the exact location. This is probably a ticky-tack leak problem....may have happened during transport of the tractor? Yes, this could be a "lack of attention to detail" or "testing" problem, but it's still small. Nobody's asking to split the tractor and replace a hydraulic pump.
Rest assured your Kioti CK3510 is a fine choice and will serve you long & well. I've used a Kioti 45HP at a neighbor for a 3 day drainage project. It was a good tractor....for a Korean, reverse-engineered Kubota. The neighbor paid 20% less and had more HP and a cab. I had to adjust to the loader operation, but it was way smoother than one of those JD loaders that feels like some other company designed & built the loader as an oops, we forgot something, attachment.
You bought a good tractor....but we still may make fun of you! I forgot to mention you probably waited for this too, not to mention any comments your wife may be making about your purchase.
I am sorry you're getting to know your Dealer's service dept sooner rather than later.
Maybe leverage this for the rest of the 2.5 gal container of UDT?
Hoping it's fixed soon......very near future "Tractor Time" will chill you out. After updating us about how your Dealer fixed this with lightning speed, You should post next time about your personal tractor skill limitations with how much you keep getting off the tractor to do things.
   / New Kioti Leaking Oil. #34
Sailorman3,
Apologies for the additional post but it just dawned on me ........ Could you use the "wait time" for repair to get going on your Simonizing time? You're probably hours away with paste waxing before your first project???
The wheels really need 2 coats back & front.
   / New Kioti Leaking Oil. #35
Sailorman3,
Pretty sure the OP is PIZZED off with his situation and Will not wax his tractor at this point..
   / New Kioti Leaking Oil. #36
I don’t think I made any complaints about the hybrid tires. I was expecting industrial which I asked for and got those. I just asked if they were the new standard. It reall made no difference anyway. I couldn’t use the tractor The way it was. Lol. I have never seen those tires before. Like I said if you have nothing good to say move on. It’s nothing for you to comment about here.
So what's the latest bro?✌🏻
   / New Kioti Leaking Oil. #37
Funny how quickly folks are to respond that this tractor is a joke but slow to respond if they have it fixed.Just my observation..
   / New Kioti Leaking Oil. #38
I’d like to know what the problem was. I got a dk4510 that leaks a little hydro from top of the transmission. Been doing it since it was new. Tractor is 2 years old now. Problem? Naw. Don’t leak nuff to worry bout. Plus I’m used to running ragged out stuff. You mentioned something bout cat and quality control. Have you ever bought brand new cat equipment? 2020 12m3 motor grader. Quarter million dollars. Steps were bent. Beacon light had no switch. Low fluid all the the way round. Short in a ground. And no inner air filter. Cat is great but qc is the same with any brand on any equipment. You always got a few guys in whatever line of work that just wants the job done regardless if it’s right or not. I’ve seen it in the electrical field too. Hope you got it fixed. But please do tell what the culprit was.
   / New Kioti Leaking Oil. #39
I guess the Joke tractor MUST be fixed.(y)
   / New Kioti Leaking Oil. #40
Hey coobie, I think it's rude not to reply don't you?✌🏻
2022 JOHN DEERE 331G LOT NUMBER 96 (A53084)
2022 JOHN DEERE...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
