New Kama TS354C 4x4 problem
   / New Kama TS354C 4x4 problem #1
RayHad
Just got a new Kama TS354C with 7 hrs. on it. First time I put it in 4 wheel drive there is a knocking noise coming from underneath. Any help would be appreciated.
Thanks,Ray
   / New Kama TS354C 4x4 problem #2
Be sure the lever is fully engaged. when going into 4wd you need to be slightly moving as you engage the lever to allow the teeth to line up and fully engage. also sometimes you will have to back up slightly to disengage. Never operate in 4wd on hard surfaces.
Thanks for the help. I tried engaging while moving,it did'nt
work. When engaged it makes knocking noise in forward, reverse and nuetral while moving.
2008 Ford F-750 SD Roll Off (A50860)
2008 Ford F-750 SD...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
UNUSED Artificial Grass Turf (A50860)
UNUSED Artificial...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2012 John Deere 7280R MFWD Tractor (A51039)
2012 John Deere...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
