New JD x320
   / New JD x320 #1
ccwasson
Carbondale, IL
John Deere X320
I just purchased a JD x320 used with 66 hrs :). Looks new. Any user tips, cautions or advice? Looking forward to getting to know the x320.
   / New JD x320 #2
Welcome to TBN. Congrats, the X320 is a good mower with the reliable K58 transmission. Just follow the maintenance schedule in your owner's manual and the mower will last for decades.
   / New JD x320 #4
Welcome to the forum from Canada.
   / New JD x320 #5
Welcome from Ohio
   / New JD x320 #6
Welcome to TractorByNet!
I moved your thread to the John Deere Lawn & Garden forum. :)
   / New JD x320 #7
Just bought a X320 and the lift system is hard to lock and the dealer said it can not be fixed so I am upgrading to a X360. The steering is also to hard to turn for my wife so the X360 should solve all the issues with the hydraulics for the lift and steering.
   / New JD x320 #8
1. There is a Deck lift assistance spring if you don't have it.
2. The lock lever can be very difficult if the front drag bar is tightened too tight. It gets tighter when the deck is lifted up. If too tight, it can bind before the lever gets fully depressed and can't lock at all (I know from experience with a 42 inch deck). If you loosen the front bar, you will likely have to adjust the rear links down to keep the deck level. Problem is the measurement of the height adjustment knob may be off, but you should have an easier time locking the lever and the cut will be level. You'll just have to figure out the actual height by trial and error.
   / New JD x320 #9
I did read the manual and you are correct and thank you for your help but the steering is still to heavy for my wife. I just wounder why the mechanic from the dealer didn't know about this simple adjustment and that makes me lose confidence in the dealers ability to repair any thing that would go wrong. I still have a problem with the collection system. The cover will not close on the left side unless I push it down and then it opens while mowing and I get covered with grass unless I stop and close it again. Do you have any suggestions?
   / New JD x320 #10
The x360 is the way to go.
As far as the collection system, I am not sure what model you are talking about. One of the rear baggers or the MC519 cart? All use a powerflow adapter on the deck. Are you complaining about the seal to the deck or the tube that goes to the cart or rear bagger? The tube used to be a two-part, but some models have been upgraded to a one-part tube that is less likely to come apart or clog. Since you mentioned cover, That could be the cover of the rear bagger or the cover for the MC519 cart.
Also, not all dealer service departments are bad. I just got my X304 back from the dealer. I had rebuilt it (had 1555 hours) and stripped the mowing deck and replaced every moving part (should have bought a new deck). It made a horrible noise and was tearing bits of the belt up. I kept buying new parts (was going to buy a new PTO) and eventually the parts department manager took pity and told me to bring it in and let their guys look at it as one hour of diagnostics was cheaper than the parts I was getting ready to buy. Brought it in on a Saturday morning and demonstrated the noise issue to the service manger. He had no clue. On the next Tuesday, I get a call that it was fixed. Cost, $68. The old deck was slightly bent and a blade was just barely hitting the deck when in the normal position. It did not do that when I had the deck flipped over. I mowed with it this last Saturday and it left my lawn looking better than my new X310.
Pallet Fees (A50774)
2011 Ford Ranger Pickup Truck (A50323)
2011 Ford Ranger...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50774)
WE DO NOT...
Willmar 4300 Wrangler Loader (A51039)
Willmar 4300...
2010 CAT 140M MOTORGRADER (A50854)
2010 CAT 140M...
2013 JOHN DEERE 470G LC EXCAVATOR (A51242)
2013 JOHN DEERE...
