New Holland TN65s pto won’t engage
/ New Holland TN65s pto won’t engage #1
Smz
9682 new holland
Helping out neighbor, pto lever moves slightly but will not pull up and engage. Cable from lever seems ok
/ New Holland TN65s pto won’t engage #2
"Cable from lever SEEMS ok" This was confirmed how? You might want to locate and remove the clevis pin on the clutch side (item 6 in the diagram) and see how the lever and cable operate with the pin out. That might help narrow down the problem.
Item 13 will move about 1/4 inch, with or without Clevis connected. Didn’t want to force it and risk more damage
/ New Holland TN65s pto won’t engage #4
Force it how? It won't move without effort. The fork it's connected to is trying to compress a clutch pressure plate. If you can't move the lever with a LARGE like 18" Crescent wrench or a two foot length of pipe you're going to be splitting the tractor anyway. You won't be harming anything that isn't damaged already.
/ New Holland TN65s pto won’t engage #5
But the lever snd vable now move fully?
Update, got it to move with ratchet strap and prybar. Pto kicks on and off now. Not sure why it was locked up but hopefully won’t happen again
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
2013 DODGE CHARGER (A63276)
2013 DODGE CHARGER...
2017 Ford F-550 4x4 Ext. Cab Auto Crane 4004EH 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
UNUSED IREV HIGH-END 2 WHEEL ELECTRIC VEHICLE (A64281)
UNUSED IREV...
UNUSED WOLVERINE HYD AUGER ADB-13-1218R (A64281)
UNUSED WOLVERINE...
