New Holland loader
   / New Holland loader #11
The joystick is an option when you buy the loader. I have used a TN75 with 32LA loader that was ran off rear remotes using the levers as it didn't have the joystick. The old tractors all ran off two lever systems (my old Ford 4000 had it mounted under the seat so it was a ackward system). So since the advent of the loader they have been run off standard remotes it is just recently that they started going to joysticks but it isn't standard, most dealers just figure it in on their price now though as it is a easier system.
And Jim, whitetiger didn't say the joystick was "unneeded", just that not having one doesn't mean the tractor is held together with baling wire and duct tape (jury rigged).
And Mike, I am fairly certain whitetiger knows the standard way New Holland sets up tractors and New Holland doesn't install the loaders, the dealers do (like Whitetiger works for). New Holland gives the dealers the option of buying a joystick to work the loader but it isn't standard.
After checking with dealer, my DX29 is a 2002 model. The 4 mounting holes are 6"x4" and I checked the NH 14LA loader mounts today and they are the same spacing. (Am I correct in saying the 14LA is the model for the DX29?)The paint on the loader is not the greatest and peeling on some edges. The loader and bucket have some scratches but otherwise in good shape. Haven't yet discussed price. Any suggestions. There is no warranty and no joystick at this time. No quick attach bucket and the paint is not great. I am guessing $750.
I just bought a large ag tractor grapple bucket and HD pallet forks for my Case ih maxuum 125 pro. The grapple bucket fits perfectly on the tractor and has the newer global carrier attachment that is now being used on all ag loaders. Paid $1500 and never been used but is sun faded. The list price on these is over $3000 plus shipping. The pallet forks cost $400 but need a little modification but are more HD than use on skid steers.
I will agree that a joystick is the way to go but I wouldn't be surprised if cost is over $1000 through parts. Disadvantage of rear remotes is the constant movement from one control to the other and can't do 2 movements at one time. I have run lots of older ag tractor that had 2-3 lever spool controls on the loader. It isn't horrible. If I didn't have rear remotes, it would be definitely joystick.
By the way, he also had a 16LA and two 18LA loaders that appeared to have never been used. Also had a 12LA and used 7308.
   / New Holland loader #13
It's "jury rigged" because it's not the standard way NH installs loaders on tractors.
If the joystick is an option for a loader, what is the standard way?
I have installed probably 200 loaders in my 30 years of working for MF, Ford, White and NH. More than half have not had a joystick. Loaders have been around for a **** of a lot longer than joysticks.
Later this week I an installing a loader on a new 4000 series tractor and they do not want the optional joystick. It will be plumbed the standard way, plugged into tbe rear remotes.
   / New Holland loader #14
If what you say is true, why don't manufacturers just skip that "unneeded joystick" and use rear remotes? Perhaps a better term than "jerry-rigged" is to call it a kludge, made of components originally intended for some other use.
If you buy a new tractor with a loader, it comes with a joystick. If you buy a new tractor with remotes, it does not come with a loader. Yes, they are both options, but they are unrelated except that they both use hydraulic power. I cannot imagine using a loader by manipulating two remote levers. Have yoiu ever done that? I have operated two control loaders, but they were conveniently located where I could operate both levers with one hand. I've never seen remotes like that.
I looked in the NH price and data book today, joystick is still in the Option coloumn.
I did not know there were rules for what is and what is not to be plugged into the rear remotes.
   / New Holland loader #15
I know NH dealers install the loaders and not the factory. Poor phrasing on my part. If half of the loaders whitetiger has installed have not had joysticks, it also means half of them had them. I wonder what the pecentage goes up to if only compact tractors are considered?
Regardless what the percentage is, it's irrelevant. If I was looking at a compact tractor with a loader and it didn't have a joystick, I would consider it jerry rigged, which is what I said in my original post. Since I'm the buyer, my opinion is the only one that matters:), hence my advice to the OP. Having the salesperson, technician or owner tell me "the joystick was always an option" wouldn't matter. No sale.
   / New Holland loader #16
Regardless of what they fit , if they are selling them for scrap price i would buy them all . "Never look a gift horse in the mouth" . They would adapt to many types of similar sized tractors $$$$$$$$.
   / New Holland loader #17
Robert and Whitetiger, I’m really surprised at you. You are both “standing in left field and throwing curve balls.” MIkePA said nothing whatsoever about baling wire and duct tape. Those are your words. I also never said that Whitetiger said anything about a joystick being unneeded. I used quotes around the phrase “unneeded joystick” for the same reason I would if I said you guys are talking “smack.” It means that phrase is slang or a borrowed phrase that is not my own.
I went back and read MikePA’s comment about the joystick. He said nothing about the joystick not being an option. He said it was the standard way New Holland installs loaders. Of course it’s an option. The whole loader is an option. The loader bucket is an option too. Would you disagree if I said the standard way of installing a loader is to have a loader bucket? If I go to a NH dealer who has 25 new tractors with loaders on his lot, how many of those tractors will not have a joystick? If I’m a dealer and order a “loader-ready” tractor from New Holland, what do I get? Do I get a tractor with rear remotes? Of course not, the standard way a loader-ready tractor comes configured is with a joystick and the loader posts installed from the factory.
Whitetiger, you may install a loader onto a 4000 series tractor without a joystick. It will work with rear remotes. Nobody has said it will not work. However, when you look in the loader operator’s manual, will it describe how to use the rear remotes with the loader or will it describe how to use a joystick to control the loader? I feel silly even asking this question.
The whole reason for this discussion was to make a recommendation to Radman1 about installing a loader. I’m pretty sure both MikePA and I want to give him the best advice based on the fact that he said he would probably sell the tractor. We both feel the loader with a joystick would enhance the tractor, while using the rear remotes might actually lessen the attractiveness of the tractor to a buyer. You are welcome to disagree. I could sure be wrong, but I don’t think we are wrong about our description of this configuration on this DX29. Telling him anything different makes me feel like a used car salesman who is trying to sell a car without a title.
BTW: This is a fun discussion and I'm not one to shrink from a good debate. Please be assured that I respect both of your opinions and hope I have not been offensive.:)
   / New Holland loader #18
Jim, there are no hard feelings but I felt like you and Mike were incorrect. You were the first person in this thread I saw refer to the Joystick as "unneeded" (your term). Whitetiger said that these loaders can be installed either with or without the joystick option. There standard way is without the joystick as the basic loader doesn't come with it. Same with the bucket, the loader doesn't come with one because not everyone needs the bucket or the same size or type bucket. Why make everyone pay for options they don't need or want, if I only need a loader for moving pallets then why would I want a bucket as a standard item?
And a "loader-ready" tractor is no different then buying the XLT model F-150 over the base XL. You get certain options as standard features then. In this case the joystick is one of those features.
Basically we are all saying the same thing but using different words. While I agree that the joystick is a better way to run the loader and is what you will find on most modern tractors now it isn't "standard". And to say not having one makes the tractor "jerry-rigged or jury-rigged" doesn't make sense to me. Just what does "jerry-rigged" mean? To "me" it means cobbled together any way possible. Just because a loader doesn't have the joystick option doesn't mean it is cobbled together (though putting a blue loader on a red tractor is getting close;)).
If I知 a dealer and order a 斗oader-ready tractor from New Holland, what do I get? Do I get a tractor with rear remotes?
And just for fun, when I bought my TN65 it was a loader ready tractor and it came with a joystick that ran the "rear-remotes":D Mid mount remotes were not available back then so the joystick just replaces the two standard levers to operate the rear-remotes.
This was a fun discussion and if I was in radman's situation I would just forget about this since he plans on selling the tractor anyway. It seems like a headache trying to make sure his tractor is compatable with this loader and even if it is any prospective buyer will look at the red Case-IH tractor with a blue New Holland loader and think it is cobbled together regardless to if it has a joystick or not.
   / New Holland loader #19
Mike, you are absolutely correct. New Holland routinely FACTORY installs midship joystick valves and loader mounts on most models of their compacts. Of course, these components can still be dealer installed as well, and must be on a few models. For any compact tractor's loader attachment NOT to be operated by a joystick would be far more the exception than the norm in the last decade, as every member participating in this thread knows full well. 'Jury-rigged' is probably a little harsh, though. One reason the joystick is an option rather than standard with the loader is that a joystick can be ordered and used with a front plow or snowblower. Each of these attachments can use two hydraulic functions, and the joystick ergonomics are as natural for them as for a loader.
   / New Holland loader #20
Rick, aren't the models that come with the joystick already on ordered as loader ready tractors? If so what other options are installed to make these tractors loader ready? Is it just the remotes with the joystick instead of two levers? Do the loader mounts come on also?
2016 Case CX55B (A55973)
2016 Case CX55B...
UNUSED 1RANCH 1REAS WOOD GRABBER (A57193)
UNUSED 1RANCH...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55852)
2021 Chevrolet...
2016 Chevrolet Tahoe SUV (A55973)
2016 Chevrolet...
2024 Yongkang Liqian LQVC 2 Passenger Electric Car (A55853)
2024 Yongkang...
Adams 6 Ton Hydraulic Lime Spreader (A55315)
Adams 6 Ton...
