Grapple New Grapple bucket on the way.
   / New Grapple bucket on the way. #1
Kays Supply
Southern Illinois
Iseki TA 207
We have had a couple major wind storms here in the past few weeks. I finally pulled the trigger on a grapple bucket for my mini excavator. I have to make a mount to fit my machine. I'll post a picture when I get it mounted.
   / New Grapple bucket on the way. #2
What machine is this going on? I have a Bobcat 325 and I'm itching to weld a thumb onto it. Where did you get this bucket?
It is going on a Yanmar VIO 27. I also wanted a thumb, but I use my machine for plumbing installlations. The thumb, even folded ,would make it hard to get under footings. It would be that much farther to hand dig. I found it on Ebay. I don't have the name handy but the phone number is 724-694-3390. It is made to fit a quick tach on a Dingo walk behind skid loader. They are going to weld a flat plate on the back not the Dingo mount. It is 27" wide. They make them in several larger sizes. I plan to weld a bracket on the back just like a bucket has. My Yanmar has a hydraulic quick coupler for the bucket. I can change back and forth in just a couple minutes while sitting on my seat. As soon as I get all the materials together to make the mount, I'll post some more pictures.
The best part, it cost the same as a hydraulic thumb.
I have put the mount on the grapple to fit the excavator. It works great.
   / New Grapple bucket on the way. #6
Kays Supply,
I have had the same thoughts about adding a thumb to my 110, I am leary of it getting in the way limiting me from reaching beneath. If new housing starts slow down further it may be a non issue.
Steve
I had to try it out, but then I put a coat of paint on it. I plan to put it to use today. I'll post some more pics tonight.
I am more effected by the weather than the economy here. I have some storm damage and so do most of my relatives and friends. I can get alot of use out of this for a while.
Here are some " Action Shots". I used it for several hours today. It worked better than I had hoped.
   / New Grapple bucket on the way. #10
I'm thinking you could just pull up small trees with that thing.
I like it!
2008 New Holland B110 MFWD Loader Backhoe (A51039)
2008 New Holland...
2012 Tiger 130BBL Vacuum Trailer (A50860)
2012 Tiger 130BBL...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2015 MACK GRANITE DAY CAB (A50854)
2015 MACK GRANITE...
1 Round Table (A48083)
2019 MMDI 14ft T/A Utility Trailer w/ Fuel Tank (A48082)
2019 MMDI 14ft T/A...
