New back blade user
   / New back blade user #1
roadtrash
N. Mich
kubota
I need some advice here folks...I just got a new Lawn Pride 6' back blade and all I'm doing is tearing everything up. The user manual is no help, any tips or advice will be appreciated.
   / New back blade user #2
What are you trying to do with it?
   / New back blade user #3
Are you letting the 3PH drop all the way down with all of the blades weight on the ground or lowering it to a level you want and stopping it there? There's quite a difference in how it'll work for you each way.
   / New back blade user #4
Also if you have draft control ? It can be tricky until you figure it out and then it is really handy.
I'm trying to smooth out a two track that washes out every time we have a hard rain, I don't have draft control so I try to adjust the blade height as I go, maybe that's where I'm making my mistake. Should I just make numerous passes dropping the blade a little with each pass? Thanks
   / New back blade user #6
That's pretty much the way I do it. The smoother the road gets in front of the tractor the smoother the back blade results will be. A mid mount blade is much better for this type of work, not so much ups and downs. They are hard to find and fit-up though. My father in law has one on his old Avery. Works smooth just like a road grader.
   / New back blade user #7
yea having a blade in the middle is alot better, but it cant get up close to things like a back blade can, i own a cat grader and its nice for the driveway but ya cant clean up around the edges and stuff, so each is better in a way
   / New back blade user #8
hey roadtrash:
I like your handle, are you a driver? Back to the subject, the best thing for you to do is practice and don't give up, nobody was born with the ability to cut a perfect grade even with the best of equipment, which a back blade is not. If you're trying to cut in a drive or something similar and you need it nice and flat or on a grade for drainage one thing that you've probaly found out is the tendancy to have ups and downs these blades don't have down pressure so you can't hardly control how deep they cut in virgin soil. This is what box blades with rippers were made for BUT I did'nt say you can't do it . One thing is a tiller run it where you want to work and then the loose soil is easy to or at least easier to grade you can also adjust your 3rd link to change how it cuts and also go different directions, not just back and forth but also crossways to get it at least broke up then put it where you want it. Try to change your angle on the blade sometimes the leading corner will dig and cut the whoop de do's out. remember it's a learning thing and you can't do it in one pass unless you have some very high dollar equipment . Take your time have fun
   / New back blade user #9
Markct,
Yes I agree they both have their uses. Hard to drag dirt off of a pile with a mid mount scraper. But the mid mounts are wonderful for grading/smoothing out a drive.
   / New back blade user #10
If you are trying to grade a road, set one end ahead of the other, lower that end, adjust the top link so the cutting edge of the blade trails the top a little bit. Now drive down the road with the leading edge at the edge of the road. The material you pick up will be rolled into the middle of the road. When you get to the end just do the other side of the road. Eventually, the road will begin to show a crown, that is be higher in the middle, so the water will run off to the edges. Now you'll have to decide where to turn the water out of the ditches you've made on the edges. I turn it out upstream of anyplace where the camber allows it to run all the way across the road. You can use the blade to make these turn outs, but I prefer to use a middle buster. Just lead the water away from the road. You won't have to go far it just get it lower than the edge of the road, it will spread out at the end of the turnout. Once you've got the grade and turnouts satisfactory, turn the blade around so you run it down the road backwards, that will smooth up the surface, then you can spread some gravel to firm up the surface. I like to use rocks about the size of walnuts for the first layer, and put smaller stuff on top after the first layer gets driven into the dirt/clay/sand. Crusher run, that is unwashed, gravel will firm up after a rain.
2007 Ford Focus Hatchback (A55853)
2007 Ford Focus...
Kivel Quick Attach Hitch Plate (A56469)
Kivel Quick Attach...
UNUSED FUTURE EQUIPMENT SEAT (A57193)
UNUSED FUTURE...
2018 HINO 268 REFRIGERATED BOX TRUCK (A57192)
2018 HINO 268...
2007 Freightliner B2 School Bus (A55852)
2007 Freightliner...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
