new again... ..steve, MF 135, post hole auger, tuffy 5", 6' grade blade,
   / new again... ..steve, MF 135, post hole auger, tuffy 5", 6' grade blade, #1
stevie1der
Richland , Wa.
1975 MF TO135
Its all pretty sweet if I can keep from breaking things. I wore out the drive shaft Gear head side rectangular slide shaft receiver real fast by raising it too high then the outer slide shaft, the hollow rectangular drive shaft on the deck gear box end stripped out inside. My bad. It's the old rectangular spline/receiver. I need to get this thing going again on the least amount of dimes possible, the outer shaft spline (rectangular spline) stripped and is just a free wheelin in their. Anybody got the "good fix" with a trick or the least "buying stuff" remedy in mind? Thanks for the tractor home away from home from home over the internet, aint this sweet?
   / new again... ..steve, MF 135, post hole auger, tuffy 5", 6' grade blade, #2
:welcome:
   / new again... ..steve, MF 135, post hole auger, tuffy 5", 6' grade blade, #3
What?:confused3: Maybe need a new PTO shaft?
   / new again... ..steve, MF 135, post hole auger, tuffy 5", 6' grade blade, #4
welcome but try english with grammer this time..
   / new again... ..steve, MF 135, post hole auger, tuffy 5", 6' grade blade, #5
Welcome to the forum.
Thanks. Those mechanical devices you mentioned sound real interesting. i'm on a whirlwind repair search and will return to visit more about the 'hit and miss" first. briefly though, does it have a flywheel,
or inertia wheel?
Dont tell me, one of my tractor buddies is a retired grammar teacher. I can see right now I'm in for "D"'s again. Sorry though. I had phone calls coming and going and admit I was shortening the writing maybe too much. NIce to meet you though.
   / new again... ..steve, MF 135, post hole auger, tuffy 5", 6' grade blade, #8
Well at least you know how to spell "grammar" correctly.:D BTW, welcome aboard. Best wishes.
   / new again... ..steve, MF 135, post hole auger, tuffy 5", 6' grade blade, #9
Welcome from Oklahoma.
Ken
2012 FREIGHTLINER CASCADIA (INOPERABLE) (A50854)
2012 FREIGHTLINER...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
2020 John Deere 9470R Tractor (A50860)
2020 John Deere...
2020 Case IH Farmall 130A Tractor (A50860)
2020 Case IH...
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
2018 DODGE GRAND CARAVAN (A51222)
2018 DODGE GRAND...
