Tires Need with with power adjustable rims on MF275
   / Need with with power adjustable rims on MF275 #1
oldbeagle
Durham, NC
Ford 4000 and MF275
Helping friend with a MF275 with power adjustable rims. I understand the design, but am new to it.
The left side rim is fine and is locked in place. The right side rim seems to be 'loose' and when moving forward or backward, the rim will spin in/out a little bit until it hits the stop adjusters which just seems to be bolts that go through the adjusting rails. I see there are some small widgets that bolt to the tractor hub and then slide on those rails welded to the rim which does the adjustments. Those widgets seem like they are too big, or don't fit right on those sliding rails. Anyone have an idea why the rim is so loose? As far as I know, both rear rims are the same design and size.
Are these power adjustable rims and components standardized, or are there design variations? I remember it did not have this problem previously until it went into the shop for various repairs and 2 or 3 of those 'widgets' were replaced for some reason.
   / Need with with power adjustable rims on MF275 #2
not sure if link will work for you...
http://www.agcopartsbooks.com/PartsBooksN/Viewer/book.aspx?book=agco/651451#
if not..
Object moved
guest -> view books
enter 275 select massy ferg
scroll down to... and click
REAR WHEELS (POWER ADJUSTABLE)(STD., ROW CROP, LO PROFILE)
out of the 3 diagrams they show, it shows the same part number, for 3,7,and 32 diagram numbers.
how long ago was it in the shop and for what repairs? wondering if they took wheel off for repairs and lost the originals and put some on they had laying around or got some new ones?
if there physically different, ya might want to take a old and new one off, and take to local dealer. and see if they can sort something out.
beyond above not much help. i set the old allis chalmers CA rear rims long ago. and have never had an issue since. well until tommorw the way my luck been going.
24' Free Standing Livestock Panel Swing Gate (A50515)
24' Free Standing...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
(1) 250 GALLON POLY TOTE W/ CAGE (A51244)
(1) 250 GALLON...
Homemade Water Trailer 1100-gallon tank (A52128)
Homemade Water...
1990 Ford F800 7 Yd. S/A Dump Truck (A48081)
1990 Ford F800 7...
