looking for info on replacing rear brake shoes on 2008 suzuki 400 atv 4x4. been looking on u-tube for some videos. i have got the wheel off but cant pull the brake drum off or get the hub to come out.do i have to use some kind of puller.
thanks Farmer495 think there is some kind of built up inside the drum that wont let it slide out. there is nothing stuck to the axle splines because it slides about a inch back and forth easily in the housing and the hub turns pretty easily also. going to try and make me a puller and bolt it to the hub stud bolts and pull the hub and cover off at the same time. hope it works. my 400 has the solid axle
Or that 1/8 inch thick rust ring around the outer edge of the drum.Good luck, take any puller slow and easy. You might also find the drum as worn internally that the shoes are holding it even when fully released.
