Need to Level Out Small Cliff on Property - Help!
   / Need to Level Out Small Cliff on Property - Help! #11
As said if the box blade has rippers then set them down and rip first what you want to move with the loader....will make moving the dirt easier....keep taking little bites and you'll get it done
   / Need to Level Out Small Cliff on Property - Help! #12
The only other thing nobody has mentioned is to make sure that you always work with the slope, not across it. That hill looks just steep enough to upset if things don't go as planned.
That is exactly what I was thinking. I am not interested in rolling over my brand new tractor :D
   / Need to Level Out Small Cliff on Property - Help! #14
A box blade with rippers should do the job easily. Back up until the rippers are over the "hump" - drop and rip thru the hump. This will loosen the hump and partially drag the hump into the valley. Finish moving the dirt with the box blade.
   / Need to Level Out Small Cliff on Property - Help! #15
My concern would be operating the box blade safely with the drop being so steep.
I actually did exactly this with my box blade, in an area where I removed a retaining wall. First I ran over the "cliff" several times and rounded it off without any implements, then I dragged the box with rippers. It worked perfectly.
   / Need to Level Out Small Cliff on Property - Help! #16
Dynomite!:)
   / Need to Level Out Small Cliff on Property - Help! #17
I'd use my backhoe :) BUT without my backhoe I'd do what oosik and others recommended.
   / Need to Level Out Small Cliff on Property - Help! #19
I don't know about the BX but most CUT will raise a box blade high enough so that by backing up to the ledge from the downhill side it will clear the top of the ledge. Just back up as much as you can (shorten the top link as much as needed for highest lift), dropping the scarifiers as low as they will go and then dragging the box blade forward will move a little dirt at first and then as the fill gets enough, you can back further back and continue doing this until you have the slope like you want it and the ledge filled in. I would do a box blade width at a time then move over and do the next width, continue till you get to the end.
I might use the FEL then to back drag the area to smooth it up. Likely need to plant some grass on it immediately to prevent erosion of the area.
   / Need to Level Out Small Cliff on Property - Help! #20
There's always got to be ONE in the crowd! :D
You dang straight partner!:thumbsup:
If soil conditions test for needing topsoil, add it before clean-up of sticks rocks roots etc., plant and roll grass seed, cover with straw, and water regularly for a couple of weeks. Mow lawn for eternity...
KENMORE 80 SERIES WASHING MACHINE (A54757)
KENMORE 80 SERIES...
2018 CATERPILLAR 336FL EXCAVATOR (A52707)
2018 CATERPILLAR...
1977 Ford F-100 Super Cab Pickup Truck (A56858)
1977 Ford F-100...
ATTENTION PLEASE READ (A53317)
ATTENTION PLEASE...
2018 JOHN DEERE 331G SKID STEER (A52707)
2018 JOHN DEERE...
2017 Caterpillar 249D Compact Track Loader Skid Steer (A55851)
2017 Caterpillar...
