Need to buy a tractor - concerned about emissions stuff (sacrifice hp?)
   / Need to buy a tractor - concerned about emissions stuff (sacrifice hp?) #51
I don’t think a grader that actually gets worked is a fair comparison to a 40 hp tractor that sits in the shed most of the time and only putters around half the time it is used is a fair comparison.
I do think that is a problem with having these small tractors go through regens....they are not being worked hard most of the time. The excavator neighbor and his crew NEVER run anything at half speed. If it isn't run to the max, it ain't making money. He has never said anything about the regens and DEF fluid except to keep the tanks full.
   / Need to buy a tractor - concerned about emissions stuff (sacrifice hp?) #52
So far I am 22 hours regen free on my tractor. My dealer was adamant that the tractor should run at least at 1500 RPM. No idling other than warm up/cool down. That was straight from the dealer.
It seems most of the emissions problems are (anecdotally) caused by running the tractor at idle for long periods of time, so it doesn't warm up, soot accumulates, and regen problems are encountered.
The concern of always running it at high RPM (other than the noise) is, I think, unwarranted. 100 hrs/yr (for a typical homeowner) on a tractor could be roughly equated to running a car for 100 hours at an average of, say, 40 mph. That would be 4,000 miles per year, which would be unbelievably low. In other words, I don't see running it at higher RPM's shortening the life of the engine. Especially as that is what it was designed to run at.
There will be a small fuel penalty, but again, that is a small amount. So, maybe I burn an extra 50 gal of fuel a year by running at higher RPM. So, that's $150/year. A small amount of the overall price.
I can appreciate how the economics of a commercial operation are different, though.
   / Need to buy a tractor - concerned about emissions stuff (sacrifice hp?) #53
I don稚 think a grader that actually gets worked is a fair comparison to a 40 hp tractor that sits in the shed most of the time and only putters around half the time it is used is a fair comparison.
I was thinking about that this morning. In a day I will be in a situation where the load reduces rpms below throttle setting many, many times. Might be as high as dozens of times.
Thanks for reinforcing that point.
   / Need to buy a tractor - concerned about emissions stuff (sacrifice hp?) #54
I replaced a ~28 hp gasser Ford 8N with a MF 1734e a few years ago. Stuff that would stop the Ford in its tracks brush hogging is no problem with the 34 hp Massey.
The only issue I have ever had with the tier4 regen is the undocumented requirement that the rpm has to be at or above1800 to run successfully.
There is very little odor and smoke from it. My neighbor has an older 50 hp International, the smoke plume and stench from it are formidable, if the wind is right I can smell it a quarter of a mile away. Really would not want to breath that in the drivers seat.
All in all I would say, Tier 4 emissions stuff has not been an issue for me at all. Having a tractor that is comfortable, dependable and starts easily no matter how cold it it or how long it has been sitting has been a joy.
   / Need to buy a tractor - concerned about emissions stuff (sacrifice hp?) #55
Yeah, you guys are right.
I had only ran the first 255HP machine for 8 years and 2,500hrs. I've only ran the DEF 255Hp machine for six months and 250hrs. What do I know.
+1 some of the people here don't even know that there are 4 ways to measure HP and don't even question if the hp advertised is net/gross, pto or draw bar! nuff said.
   / Need to buy a tractor - concerned about emissions stuff (sacrifice hp?) #56
Plus if I'm not mistaken you use a heck of a lot less fuel with the Massey.
   / Need to buy a tractor - concerned about emissions stuff (sacrifice hp?) #57
That to, as well as a thigh height fuel fill rather than chest high right over the battery!
   / Need to buy a tractor - concerned about emissions stuff (sacrifice hp?) #58
Well, in that case, I'm totally convinced.
Scientific Evidence has been provided.
Name the make, model, year, engine and power train on this "new DEF machine".
And then lets look it up on the Nebraska Testing Site, just to see if they've rated it.
Because we all know, a single, solitary personal anecdote proves everything.
The Internet can rest now.
   / Need to buy a tractor - concerned about emissions stuff (sacrifice hp?) #59
After running the first machine for 8 years I would say that you would know on the first day with your new machine. But you would give it a break because it's not broke in yet.... By the time you've run it 250 hours/6 month's you would know for sure if it has more or less power than the machine it replaced.
Edited to add that I know a few mechanics who work in agriculture repair shops. One told me that 50% of their warranty work was emissions related. All used tractors sold out of their dealership are deleted. Another service manager from a different dealership told me the same thing.
I have a farmer friend who's trucks drive at slow speeds along side the potato harvester for about a month every fall. There was no end of problems with the emissions. Every potato truck has since been deleted. 100 extra horse power and better fuel economy is the result of deletion. Plus extra engine life because you not asking an engine to deal with extra unburnt fuel that it really wasn't designed to deal with.
Now lets talk about how a lot of you use your tractors. They are designed to work but I read comments on here about how engines and tractors get babied. I also notice tractor operators that get maybe 20 -30 hours experience a year who think they are wise enough to know better than operators who make their living using a diesel engine all day long year in and year out. It gets interesting to say the least!
End of rant but long story short. Most of you will never run your new tractors long enough to see the real degradation in engine life and performance that occurs because of emissions. If you can buy a good tractor that is pre emissions, do it!
   / Need to buy a tractor - concerned about emissions stuff (sacrifice hp?) #60
I am sure there is a definite reduction in power with the different emissions systems. I don't think it is very much on smaller HP units. As HP increases the amount of loss would be more.
Anyway I just ordered a new 48 Hp tractor that claims 40 PTO Hp. The funny thing is both geared and HST are advertised as 40 PTO Hp. I know one of them is not correct. I hope to put mine on a PTO Dyno when I get it to find out what it is producing. Then I will delete the emissions stuff and will have it tested again. That should clear things up. I am sure there will be an increase to some degree but don't expect more than a few HP.
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
UNUSED WOLVERINE TDB-11-78W 78" BUCKET (A57193)
UNUSED WOLVERINE...
Allis Chalmer Glearner K2 (A53317)
Allis Chalmer...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2012 JLG 3246ES ELECTRIC SCISSOR LIFT (A52707)
2012 JLG 3246ES...
