need new trailer tires .....
   / need new trailer tires ..... #21
You know, I've always heard that 5-6 years is max replacement interval. I checked the tires on my camper trailer last night. They are date code 3710, so almost 7 years old. They have been indoors in either the camper's showroom or inside an fully enclosed and dark barn / garage at all times (unless driving or camping) since new. The tires show no cracking or signs of being tired. I'm very inclined to run them for another year or -gasp- two with frequent inspection. Am I delusional? Asking for trouble? Just for information, in the last year I bought Michelins for my car, new Firestones for my wife's Expedition, and a total of 6 Maxxis radials for two of my trailers, so I'm not averse to buying quality tires. I am averse to throwing money away by replacing perfectly good tires.
I'm willing to listen - enlighten me.
well, I'm not going to throw perfectly good tires away. If they are dry rotted, cracked around the sides, I'll replace. other than that. I'm putting them on the road.
I put used tires (age?) no idea on all my trailers except my camper
   / need new trailer tires ..... #22
I like Discount Tire and don't think you can go wrong with them. Just go to their website and get an idea of what's available and what it will cost you. Last weekend I needed new tires for my truck and Discount Tire was closed, so I went to Firestone and got some tires there that cost more then what I was hoping to pay, but think I got a better tire then what I saw available at Discount Tire.
For my trailer, I went to the local guy who builds trailers and asked what he wanted for a set of tires already mounted on rims. His cost for tires and rims was less then Discount Tire for just the tires.
   / need new trailer tires ..... #23
I just got new greenball tires at Costco online.
   / need new trailer tires ..... #24
By the way, I typically replace street motorcycle tires every 5-6 years. Since there's only TWO of them, it seems like a good idea for safety reasons...
Then you don't ride enough :laughing:
I'm lucky if I only go thru 2 sets of street motorcycle tires a year!
   / need new trailer tires ..... #25
ST tires have thicker sidewalls so they do not sway as much, but they are more susceptible to blowouts because they heat up easier if you have any with lower pressure, heavy loads, or drive fast. That will factor into your decision, because you know yourself. Are you meticulous enough to always check pressure before you go? Are you going to stay off the highway? Will you never over load it? If so, ST tires may be fine for you. I have had two horse trailers over the last ten years and both were moved from trailer tires to LT's because after 4 or 5 blowouts on the highway I was done with ST's. I keep the pressure good, but I also drive 70-75 MPH. I do multiple trips per year that are 1500-2000 km each way and 100-400 km trips every second weekend during the show season, so I am certainly not going to drive 55-60 MPH the whole way.
As far as spares go, I have two full spares on rims because if you are halfway through a long trip and you get a blowout, are you going to do the last 1000 kms with no spare? Not easy to stop for an hour and get a new tire on the rim while horses are on the trailer (when you stop they get restless and start kicking) and besides we often drive through the night by tag team driving. I also keep a full can of diesel in the back of the truck because open stations can be spotty at night.
As far as jacks go, the bottle jack from my HD truck would work but I never use it for the trailer. With a dual axle trailer you want a trailer aid, it is way better.
You just drive the non-blown tire onto the ramp and change the other one. 30 seconds up and down, no jacking or cranking on the side of the road while people fly by 5 feet from you. The last time I had a blow out I was pulling back on the road and my wife looked at me and said "That was 14 minutes! Nice work!" Probably half of that time was getting the spare down from the bracket under the gooseneck. I also have a four sided lug wrench because they give you better torque and are faster to spin off the nuts. plus it has a pry end to get the wheel covers off.
   / need new trailer tires ..... #26
Around here no tire shop will touch a tire over 6 years old except to dismount it.
You are exaggerating. 90% of tire shops will do whatever you ask them as long as it is reasonable, whether is is installing used tires, patching tires, and what-have-you. They may give advice like patch instead of plug, but if you lay down your money and are not being unsafe, they are going to do the job you ask them to.
   / need new trailer tires ..... #27
Sadly, that is not as true as it used to be. And totally untrue of WalMart.
   / need new trailer tires ..... #28
I bet 10 would do the things you mentioned out of a hundred around here.
1st thing they all do is look at the date code.
   / need new trailer tires ..... #29
:thumbsup:
Right you are. Before kids - at least 10-15k mc miles per year and a couple sets of tires. Since having the boys, tires age out about the time the wear out. Fortunately, dirt bike tires are going like hotcakes these days, so we're still having fun.
   / need new trailer tires ..... #30
I am using 16" load range" E " LT radial tires and getting good service
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
2016 FREIGHTLINER M2 DAY CAB (A51222)
2016 FREIGHTLINER...
2014 Ford F550 4x4 Bucket Truck with Versalift SST40 - 45FT Working Height (A51039)
2014 Ford F550 4x4...
Set of AG R4 Wheels and Tires (A51039)
Set of AG R4...
2020 KUBOTA SSV75 WHEELED SKID STEER (A51242)
2020 KUBOTA SSV75...
48ft Low Boy T/A Trailer (A49346)
48ft Low Boy T/A...
