Need new front tire(s)? (1700 2wd)
   / Need new front tire(s)? (1700 2wd)
Silly me! I used the term "better ride", what I actually meant was "better traction" or "better control". Considering I only have 5 acres and don't really travel that quickly on the tractor anyway, the quality of the ride on my back is not really a big concern.
   / Need new front tire(s)? (1700 2wd) #12
You didn't mis quote on what you said. Usually ply rating has to do with better ride, but not entirely. For a given tire size checking the rated load at full rated pressure tells you how stiff are the sidewalls on some tires. I had 12x16.5, 6 ply R4s on the rear of my 2400 and the ride was terrible. Reducing pressure only resulted in the tire coming off the rim. I found some 33x12x16.5 4 ply R3s thinking the 4 ply would get me some soft sidewalls. Nope, the tires came in at 35 psi rating of 2500# approximately which was the rating of the original R4s. Wound up with 8x16, 6 ply R1s (needed different rims for that) and run at about 15 psi and work great for traction and soft ride.
I would get the ribbed front on a 2wd tractor. I have run truck takeoffs on the front of my 4000 Ford with loader and they were like 225 radials and I mounted them on the existing Ford front 16" Ford rims. Pumped up to 40#, (rating for road use was 35#) I had the fat tire with reasonable sidewall strength but slid on turns....nothing to grip the dirt on a hard turn.
I can't seem to be able to find 8.00-10 ribbed tires. Also searched for 205/65-10. I guess I need different rims? that'd put the price higher, I fear.
Ended up going with the 6 ply from the ebay link; nobody local had it. I'd have wanted a ribbed, but that'd require different front wheels, and I have more important things to spend on.
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55302)
2012 RAM 5500...
2007 Freightliner B2 School Bus (A55852)
2007 Freightliner...
PT Gravity Flow Wagon (A56469)
PT Gravity Flow...
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
Hydraulic Press (A56469)
Hydraulic Press...
Hercules Pesticide Applicator Tank with Nozzle (A55852)
Hercules Pesticide...
