sd455dan
Super Member
- Joined
- Oct 23, 2012
- Messages
- 6,294
- Location
- North Idaho
- Tractor
- Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
was a return..
Have you checked the filters are staying full, have seen a couple times where a slight leak occured at the filter gasket and also resulted in NO JOY
Is this the CAV set up or the Simms, have had more problems bleeding the CAV setup The Simms has a priming lever on the injector pump, The last Cav I worked on was primed by a lever on the seperate fuel pump -but it was a Leyland tractor
If it is the Simms (in line pump) you could try the cold start enrichment basically open the throttle up wide open push the pivot pin in that is connected to the throttle -It SHOULD click and stay in , reduce the throttle setting to 1/2 and try to start it... If it does start the pin should immediately pop back out reduce the throttle... good luck and hope this helps
