Need help with a TSC 16' electric hay elevator
   / Need help with a TSC 16' electric hay elevator
What killed this ole conveyer was the brass bushing the held the shaft for the 12"v belt pulley and the 3" sprocket. The metal wasnt thick enough so I welded in a piece of angle iron for support. I found a flanged needle bearing to use instead a brass bushing. After installing the shaft and pulleys/sprockets I figured out I needed a pillow block bearing to keep the shaft from being pulled by the belt or chain.
I basically rebuilt the drive chain shaft completely due to all the bushings were shot and the shaft was worn. Sozzie helped me out with finding a new drive chain sprocket. Thanks again!! Next spring I need to make a shield for it. My wife about stuck her boot in the drive belt while moving hay. :banghead:
I ended up with $200 when it was all done. Thanks for all the input.
2012 International Prostar (A56435)
2012 International...
JOHNSON JW12 OUTBOARD MOTOR (A58374)
JOHNSON JW12...
2018 John Deere 30G Mini Excavator (A56857)
2018 John Deere...
2018 Ford F-350 4x4 Ext. Cab Knapheide Service Truck (A55973)
2018 Ford F-350...
2018 Dodge Charger Sedan (A56859)
2018 Dodge Charger...
FIMCO 60 GALLON SKID MOUNT SPRAYER (A52708)
FIMCO 60 GALLON...
