Need help with a TSC 16' electric hay elevator
   / Need help with a TSC 16' electric hay elevator
Last week I picked up a 8" v belt pulley 3/4" bore. Im not sure if thats too small now. I picked up a 3" sprocket 3/4" bore 40 chain to go on the same shaft as the 8" pulley.
I think I need to swap the 3" sprocket 40 chain for a ?" 41 chain sprocket. Im not sure if 3" is correct, I just took a guess.
   / Need help with a TSC 16' electric hay elevator #15
The smaller diameter pullys will slow it down some. Can you take a sprocket with you for matching up the chain #? Ken Sweet
Yes I can bring it in now. Its welded to the shaft so thats why I couldnt bring it in earlier.
Thanks for the info Mr Sweet, its helping me out! I found a 1/2 hp motor for $20 from a friend. I think Ill swap out the 40 sprocket out for a 41 and regroup from there.
   / Need help with a TSC 16' electric hay elevator #17
I think it would be best for you to call into our technical department... ask for Brian. 800-842-5349. Thanks.
Brian was a lot of help!! He got me all squared away with what I need. Thank you Sozzie!
I got her up and running!! Ill post up some pictures in a few days on how it turned out. Thanks for the help guys.
Here is what I ended up with. I found a 1/2 HP electric motor with a pulley on it for $20. I used a 12" weld-a-pulley, they were way cheaper then a cast pulley plus I able to use my Miller 211 MIG welder on it. I found an old belt hanging up in my barn and used it.
Behind the 12" pulley I used a 3" 40 chain sprocket and connected that with a 6" 40 chain sprocket.
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
New/Unused Pallet of Ground Protection Mats (A57454)
New/Unused Pallet...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2016 FREIGHTLINER...
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
532 (A52708)
532 (A52708)
