Need help with a TSC 16' electric hay elevator
   / Need help with a TSC 16' electric hay elevator
Last week I picked up a 8" v belt pulley 3/4" bore. Im not sure if thats too small now. I picked up a 3" sprocket 3/4" bore 40 chain to go on the same shaft as the 8" pulley.
I think I need to swap the 3" sprocket 40 chain for a ?" 41 chain sprocket. Im not sure if 3" is correct, I just took a guess.
   / Need help with a TSC 16' electric hay elevator #15
The smaller diameter pullys will slow it down some. Can you take a sprocket with you for matching up the chain #? Ken Sweet
Yes I can bring it in now. Its welded to the shaft so thats why I couldnt bring it in earlier.
Thanks for the info Mr Sweet, its helping me out! I found a 1/2 hp motor for $20 from a friend. I think Ill swap out the 40 sprocket out for a 41 and regroup from there.
   / Need help with a TSC 16' electric hay elevator #17
I think it would be best for you to call into our technical department... ask for Brian. 800-842-5349. Thanks.
Brian was a lot of help!! He got me all squared away with what I need. Thank you Sozzie!
I got her up and running!! Ill post up some pictures in a few days on how it turned out. Thanks for the help guys.
Here is what I ended up with. I found a 1/2 HP electric motor with a pulley on it for $20. I used a 12" weld-a-pulley, they were way cheaper then a cast pulley plus I able to use my Miller 211 MIG welder on it. I found an old belt hanging up in my barn and used it.
Behind the 12" pulley I used a 3" 40 chain sprocket and connected that with a 6" 40 chain sprocket.
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58214)
1999 WEST WIND...
2016 ELDORADO NATIONAL EZ-RIDER CNG BUS (A58018)
2016 ELDORADO...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
2019 Hitachi ZX300LC Hydraulic Excavator (A56857)
2019 Hitachi...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56435)
1992 Talbert 70...
BLANTON 12' DRAG HARROW (A52708)
BLANTON 12' DRAG...
