Need advice on purchasing my first tractor
   / Need advice on purchasing my first tractor #1
JorgeSerna
ZAPATA
None
I am looking for my first new tractor and have no idea what brands to avoid or look into. I have 8 acres and will be maintaining the road, shooting range, mowing 1 or 2 acres, digging a small pond and lifting over 1500lbs often.
I have Kioti, Kubota and LS dealers 90 miles away and Mahindra, Branson and JD are further away but still within 3 hours drive.
Should I look into a 5ft or 6ft wide tractor for my applications above?
My old tractor was an International 444 which seemed bigger than the L3901 or CK3510 that I saw this week.
   / Need advice on purchasing my first tractor #2
I would not recommend a tractor for mowing or digging a pond.
What is 1,500lbs that you need to lift often and do you just lift it or do you need to move it? If move it, how far and over what terrain?
Wider tractors are always better, unless their not. We need more info.
L3901 is not capable of lifting 1,500 lbs...
   / Need advice on purchasing my first tractor #3
A tractor isn’t a good tool for digging ponds ponds. You need a bigger tractor to lift 1500 pounds than a L3901 too.
   / Need advice on purchasing my first tractor #4
Welcome to the tractor/zero turn forum. I say go with a bigger L4701 and a loader. Price out a rear finish mower, then price a commercial zero turn mower, then decide.
We mowed with Dad's MF1635/RF500 60" rear finish mower, bought a Big Dog Zero turn 2 years ago. Can get more done with the Zero turn faster.
keep us posted.
   / Need advice on purchasing my first tractor #5
Your 444 is about 33% heavier than a 3901. It is also at least 500lbs heavier than a 4701. If you want Kubota, you need to go to MX or bigger. Do you even want bigger? Is your land open or wooded? Hilly or flat?
Digging a pond seems like a one-time thing. May be better to rent something. 90 miles from dealership is out there, so renting may not be practical.
You have not mentioned budget. LS, Branson and Kioti will get you more tractor than Kubota or is for the same money. There are other considerations like dealership. For some people resale value is important, not so much to me. I have done no research on Mahindra as my home boss was told by her engineer/farmer co-workers to avoid them. I don't cross the home boss.
Yes the 444 is heavy, my buddy moved it last week with his 97 Silverado and instantly realized it was heavier than his l2501.
My land is flat with small brush and trees. My land is sandy loam so 4x4 is a must.
I actually went to see the MX4500 if that's correct model and they were out of those. The pond is small and think the box blade could handle it or I can rent a backhoe for the day.
The heavy stuff to move are pallets of material.
I did search Ebay and noticed Kioti is about non existent while there is alot of Kubota, basically trying to search resell value.
Budget probably 30k max on the tractor and loader since I have to buy a trailer and implements also.
   / Need advice on purchasing my first tractor #7
Take the time to check out Branson. I'm in the opposite side of Texas. Branson dealers are farther for me than other brands, too...but only about 90 miles... but they have some good deals. Check out the dealership in Caddo Mills for some idea on what you get for the money. It may save you driving 3 hours, or at least let you know what to expect. They have a 42 HP tractor about the same weight as a 4701 (15:series) that they have priced at $27k or so with loader and 4 implements included. HST is about 1k more.
Kubota is about the only one who even offers a 4x2 in this size anymore. Most will have front wheel assist (4x4).
Some other questions to ask yourself... Cab or open station? Gear transmission or hydrostatic?
Bigger tractor may entail bigger trailer and/or truck, too. I decided that for the size I needed it would be cheaper to pay the dealer to haul it than buy a trailer and truck big enough for what I need. I have just under 20 acres and will not need to move the tractor to other places.
   / Need advice on purchasing my first tractor #8
I have 8 acres and will be maintaining the road, shooting range, mowing 1 or 2 acres, digging a small pond and lifting over 1500lbs often. My land is flat with small brush and trees. My land is sandy loam so 4x4 is a must.
You need a tractor with a bare tractor weight of 3,700 pounds to 4,000 pounds.
Bare tractor weight is a fundamental tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used. Shop your weight range within tractor brands. Budget will eliminate some choices. Collect a dealer brochure for each tractor model in your weight range.
This is the mid-weight of compact tractors, a high unit volume segment. Every tractor manufacturer offers at least two models, an economy and a deluxe tractor, in this weight range.. All offer HST. All are 66" wide, plus or minus a smidge. All will comfortably pick up 2,000 pounds with the loader. Horsepower options are 40-horsepower to 60-horsepower.
One example conforming with above recommendation is a Kubota MX series tractor.
I have Kioti, Kubota and LS dealers 90 miles away.
The design of the (Ferguson) Three Point Hitch tractor has been marketed in the USA since 1939 -- 82 years in 2021.
The basic design is generic. Ferguson's Three Point Hitch patents expired around 1955.
Kubota and Deere dominate the market through 6,000 pound bare weight tractors.
I searched Ebay and noticed Kioti is about non existent while there is a lot of Kubota,
The up and coming tractor brands are Korean: Kioti, LS and Branson. There are other Korean brands. You have to critically assess dealer stability while shopping minor brands. Most or all of the Korean tractor brands have AROUND 1% compact tractor market share in the USA under their primary trademark. I am skeptical even the most successful Korean tractor brand exceeds 2% market share under it's primary trademark.
Korean manufacturing labor is paid 50% of what Deere pays its union work force. Japanese manufacturing labor is paid 70% of what Deere pays its union work force. Labor costs strongly influence tractor prices.
   / Need advice on purchasing my first tractor #9
I would hire someone with a Dozer to do the pond work, I'd hate to tear up my new tractor doing things that it was not designed to do. What size hp tractor are you thinking about?
   / Need advice on purchasing my first tractor #10
The fundamental importance of TRACTOR WEIGHT eludes many tractor shoppers. Tractor capability is more closely correlated to tractor weight than any other specification.
International Harvester 444 Dimensions​
International Harvester 444 Weight
Gas Shipping:3800 lbs
1723 kg
Diesel Shipping:3920 lbs
1778 kg
Gas Operating:4070 lbs
1846 kg
Diesel Operating:4200 lbs
1905 kg
1 Network Camera (A48083)
1 Network Camera...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A51039)
John Deere 5090E...
12in Backhoe Bucket (A51039)
12in Backhoe...
2020 KUBOTA RTV...
Lot of 5 Dell Laptops (A48083)
Lot of 5 Dell...
