Need Advice on a ZD221
   / Need Advice on a ZD221 #1
sjm1580
Southwest Florida
Kubota L5740HST, Takeuchi TL220, Kubota zd221
I am ready to pull the trigger on a new zd221 with a 48 inch deck. We have some tight spots throughout the yard and I felt the smaller deck would help in that reguard. I wanted to get some feedback on the machine and thoughts on the smaller mower deck.
Is the deck to small, in that you cannot mow tight to obstacles as the deck does not stick out far enough from the tires?
Any thoughts on if the mower lift, is a worthwhile addition?
Thanks in advance for the help.
Steve
   / Need Advice on a ZD221 #2
The deck is pretty close to the rear tires ,it isn't a problem getting close to things but the deck isn't going to sneek under bushes etc. I went with the 48" as well as my lawns are less than flat and level. I got the lift but have not used it yet,heck haven't used the machine at all yet !
   / Need Advice on a ZD221 #3
I bought a ZD221 last year with the 48 inch deck for the same reason as you, tight spots that a 54 inch deck would not be able to fit. I've got several areas where I have to lift up the discharge chute in order to squeeze by. The deck only sticks out a couple inches past the rear tires on the left hand side, so you have to be careful when edging close to objects. I've already scraped the tire a couple times by accident. If you have trees with low hanging branches or shrubs you will probably have to hit those spots with a trim mower or string trimmer since the deck doesn't reach out far enough to let you ride by without getting hit in the face by the branches.
I would get the mower lift unless you already have something like a MowJack to raise the machine. It helps a lot with cleaning the deck and blade removal / installation. I like being able to drive up next to the hose, crank up the front of the mower in less than a minute, and spray off the grass that gets stuck on the bottom of the deck.
As for general machine comments, the engine and fuel economy is awesome. I rarely ever get RPM drop and when I do it's in thick clover. You will want hearing protection, although in my experience the Kubota is quieter than a similar size Kawasaki gas engine. The blades are an odd size, not sure if there are any aftermarket options yet. I just bought a replacement set at the dealer for $71 + tax. One of my front tires got a slow air leak shortly after purchase but I fixed that with slime. I actually did both front tires and both have held their PSI since last fall. The radiator screens collect quite a bit of grass in dry conditions, so you have to periodically stop and clean them off or else risk the engine temp climbing.
I wish Kubota had used swivel anti-scalp wheels on the 48 deck like they do the larger models. It's not a big problem, just would have been nice instead of fixed wheels. If you want to change the height of the fixed wheels you have to unbolt them and reinstall in a different hole. I always leave mine in the lowest position since I cut at 3 inches.
The worst thing about the Kubota, in my opinion, are the grease zerks on the shaft that goes from the engine to the transmission. You are supposed to grease these every 50 hours, and a couple of them are tough to reach. One of them has to be accessed from underneath the back of the machine where there is not much clearance. The ones on the mower deck shaft aren't too bad, I will rotate the blades by hand to get the U-joint into the right position to get to the zerk.
   / Need Advice on a ZD221 #4
I, too, am thinking about a ZD221. I looked at the GR2120 also. It has the same engine, but I like the commercial aspects of the ZD221 better. The GR2120's claim to fame is the 4-wheel drive, but my property is flat and I have a lot of trees, so the ZTR is a better fit for me. I appreciate jvgillow's insights. If you've got yours now, I'd like to hear your thoughts too.
   / Need Advice on a ZD221 #5
Almost got two hrs. on her ! Very nice machine ! I was a little worried about the weight but even in very wet spring conditions it hasn't been a problem. Less turf damage than the freedom z skag or the 36" skag,that I traded, maybe the extra weight is on my side ! Haven't greased it yet but my book is calling for dailey 8-10 hrs. for the deck & shaft, can't wait for that !
Don't hear the engine at all, just the deck. Beautiful cut, power lift deck is sweet ! Not missing that ethanol gas at all !
   / Need Advice on a ZD221 #6
Did you end up with the 48" deck? That's what I am considering. I'm also trying to decide whether or not to get a mulching kit with it. Any ideas on that?
   / Need Advice on a ZD221 #7
I did get the 48" deck, haven't seen the mulching kit in action,I didn't get one.
   / Need Advice on a ZD221 #8
I'm having trouble locating one. My dealer says the nearest one is 600 miles away and that nobody likes to carry them in stock, as they don't move very well. Apparently, they are a little too expensive for a typical homeowner machine, but too underpowered for the liking of the commercial users. They are sort of in a niche between two markets. At any rate, I've compared it to the Grasshopper 321D, which uses the same engine, and I think the Kubota has more features for less money (the power deck lift, for example, which is an option on the Grasshopper). Anyway, I'm not sure how to proceed. My dealer says he'll call the factory in Ohio to see if they have any, if I want him too, but I'm still trying to decide.
   / Need Advice on a ZD221 #9
I have had a ZD 1800 for about five years and could not be happier. The ZD 1800 was replaced by the ZD221. I have the 54" deck ( I down sized from the 60" ) and there are one or two places in my 1 acre yard that I need to be careful as the is not totally level and I can span a high point and lightly scalp the grass. For the homeowners I would say either 48 or 54 but no larger deck size. By the way I have had no trouble at all with the mower just normal annual service. I have cut a 100 by 2300 foot grass runway many times with my ZD1800 and it does a great job in about an hour. Fantastic mowers
2012 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2012 STEPHENS...
48ft Low Boy T/A Trailer (A49346)
48ft Low Boy T/A...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2018 Skyjack SJ1056TH 10,000lb 4x4 Rough Terrain Telehandler (A49461)
2018 Skyjack...
