Buying Advice Need a tractor for heavily brushed/sapplinged 50ac and future maintenance
   / Need a tractor for heavily brushed/sapplinged 50ac and future maintenance
Ya I've never cut down anything quite this big before ... usually has been tall grasses and the odd sapling, this one however has seen better days. And ya the brush is 3/4" not 3/4' ... its all small stuff ... just a ton of it
I talked to one of the neighbours here and he's got a good sized rig and figures it'd be a couple days work to clear it up, so kinda saves me some costs since really don't need a huge tractor for regular brushing/mowing
   / Need a tractor for heavily brushed/sapplinged 50ac and future maintenance #12
Don't underestimate the size tractor you need if you plan to mow 50 acres after it is cleared and replanted.
MarkV
   / Need a tractor for heavily brushed/sapplinged 50ac and future maintenance #13
I suspect a UT at the minimum.. IE.. at least something pulling a 10' mower.. that is.. if he wants to get it mowed in a day or so..
soundguy
   / Need a tractor for heavily brushed/sapplinged 50ac and future maintenance #14
I am sensing a common theme in all of the replies guys... Get a dozer in to take care of it initially....Then what ever flavor of tractor suits his fancy....
I agree. A good dozer operator will get it done cheaper and quicker than you could do it yourself, and do a better job. Push it into burn piles. Either that or something with a good mulching head.
After removing the brush, typical till and grade field, some fel work to remove some hills etc
Again, the dozer can do a lot better job of grading while he is there. A front end loader is not a very good digging tool for removing hills. A box blade would do better but again a dozer or skid steer would be much more effective.
Ultimately for mowing 50 acres, figure about 2 acres/hour for a 50 hp tractor with a 6' cutter. I've gone to a 90 hp tractor and a 15' batwing mower, it really speeds thing up by a factor of about 3.
Ken
   / Need a tractor for heavily brushed/sapplinged 50ac and future maintenance #15
Agree wholeheartedly with the dozer/specialized equipment. Growing up, clearing and farming "new ground" was fairly common and it is really hard with conventional equipment. If you don't know what you are doing, it is even harder. Lots harder to blow stumps now without attracting attention too.
   / Need a tractor for heavily brushed/sapplinged 50ac and future maintenance #16
I did that exact task on ,about 50 acres of sumack and native rose bushes, small cedar, honey locust, etc. I used a 24 HP jd 770 for most. Most were 3/4" or smaller. I did hire a dozer for thicker patches and it was surprisingly fast and cheap. And a bonus is that u get a nicely cultivated seedbed if they clean up good and smooth out.
   / Need a tractor for heavily brushed/sapplinged 50ac and future maintenance #17
Ken
Yep.. I think I might considder selling my land and small tractor if I had to maintain 50ac with a 6' mower.. :) I think my 10' is small on a 10ac piece.. and love my 15' batwing.
soundguy
my problem is the property is not very well suited for larger implements, initially I was thinking to just use the atv and tow behind mower ... but after going out and seeing the prickly ash and what not, that idea went out the window ...
   / Need a tractor for heavily brushed/sapplinged 50ac and future maintenance #19
Yeeoww a 15' batwing! That will "get er done" To the OP have you considered running goats and Llamas in there? They eat the stuff on their front end and fertilizer out their exhaust...:thumbsup:
   / Need a tractor for heavily brushed/sapplinged 50ac and future maintenance #20
I am glad I saw this thread...
My gramps passed away 3 years ago. Prior to that in the early/mid 90's he had timber cut off of some hilly land to replant trees on. He never did and in that time until 2008 it grew like wildfire. The lumber company left many of the softwood trees, as well. We rented a D5 dozer, and a T130 bobcat. The D5 dozer should have been a D6 or D7, yet was capable of taking down any trees. I was completely inexperienced in driving the dozer but caught on quick...I'm just good like that, in all seriousness. The T130 was swapped out for a T270 bobcat as well as having a bucket with teeth vs. the smooth blade bucket. We tore the crap out of that dozer! We rented all of that for about 6k for 2 weeks after getting 5 extra days out of it for rain delays. We got insurance to cover 80% of all damages and than the remaining 10% is split between the company and ourselves, so we paid 10% of damages. We rented from local company which rented through a heavy equipment dealer to get the dozer. That company tried to claim that the dozer was a loss after us. We broke two windows, removed the radio antenna windshield wipers, a door handle, cab lights and fuel cap, put a stick through the rear hyrdo box (which we were not using so we didn't care), dents and dings to body, somehow getting it to overheat every 2 hours of use which needed to have it shut down for 15 to 20 minutes (which was fine, because we were regulated to so many hours of use a day). The skid steer was flipped in to a creek by my dad but we had a towing company pull it out. He had no idea how to drive a bobcat, that was entirely his fault (it cost 300 to have it pulled out and we never . I got the D5 stuck in a swamp, I guess even if it is a dozer it can get stuck. The dozer cost 700 to be pulled out. The bobcat also broke a few times through no fault of our own and having to wait on a tech to fix it was annoying, even though there was little the machine could help with.
At the end of the day, after all was paid from the previously mentioned ordeal, we paid about 8,500.
The next fall we had a friend with a Case track loader come and push all the piles together. The bulldozer could not clear dirt from the tree and brush debris. He also ripped the soil, doing a mediocre job at best. I did not pay for that portion, so I can only say that when I had that part priced out it was guessed to be 3k.
The last portion was using a rake and a scarifier to go over the land removing sticks and root debris. The cost there was fuel, about $100.
That being said, for the adventure, I would do it again, but I could have spent the money and had a professional do it in 3 days for about 12,000 vs 2 years for me and 11,500 and a whole lot of trouble. If you are wondering, the land I covered was about 12 acres.
UNUSED IRANCH SEMI-AUTOMATIC MINI QUICK COUPLER (A57193)
UNUSED IRANCH...
2019 Ford Escape SUV (A56859)
2019 Ford Escape...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
Case Compact Wheel Loader Skid Steer (A55851)
Case Compact Wheel...
2020 Peterbilt 367 (A55973)
2020 Peterbilt 367...
2015 FREIGHTLINER M2 TANDEM AXLE 24FT FLATBED (A57880)
2015 FREIGHTLINER...
