Traction My Tractor Slips Going Down Hill While Mowing
   / My Tractor Slips Going Down Hill While Mowing #11
If putting it in 4wd stops the freewheeling it is not a transmission problem and all but certain to be sliding. The tranny doesn’t care if you are in 2wd or 4wd.
What your other tractors do is immaterial. Weight/footprint, etc are apples to oranges. What is your rear tire inflation? A light tractor with overinflated turfs will skate like Nancy Kerrigan.
   / My Tractor Slips Going Down Hill While Mowing #12
The hill matters too. I cannot go down any of my hills in 2WD. I MUST be in 4WD and Low to descend safely. A lesser grade hill would be a different matter. Why your 1880 can do it, I cannot discuss.
   / My Tractor Slips Going Down Hill While Mowing #13
Try it in 2WD drive but with the diff lock engaged. With a open differential, it takes very little slippage of ONE wheel to feel like it is taking off.
   / My Tractor Slips Going Down Hill While Mowing #14
The OP suggests it's an internal issue and seems to understand the issue of loosing adhesion and sliding down a hill, yet you guys keep talking about that.
   / My Tractor Slips Going Down Hill While Mowing #15
That is because they understand what is happening.
   / My Tractor Slips Going Down Hill While Mowing #16
I got the impression the OP wasn't born yesterday. lol Not his first Rodeo, so to speak.
   / My Tractor Slips Going Down Hill While Mowing #17
If he had all the answers he would not need to ask the question. Clearly he is less than happy with the responses. That happens.
If someone can explain how a hydrostatic transmission can freewheel in 2wd but not in 4wd on the same slope and conditions I am willing to learn.
   / My Tractor Slips Going Down Hill While Mowing #18
+1. And this is why I disagree if the OP thinks it's an internal issue. Internal issues would exist in 2WD or 4WD and affect both equally. If it goes away in 4WD then it's a traction issue and not an internal issue. These "4WD" tractors are really like having an extra FWD assist driven off the RWD. If the front driveline is not slipping internally then that means the rear is not slipping internally.
   / My Tractor Slips Going Down Hill While Mowing #19
He is missing the important fact that the FWD is driven off the RWD internally. If the rear was slipping internally then the front would have no chance.
   / My Tractor Slips Going Down Hill While Mowing #20
And while we're on the topic, check the rear tire pressure. Could be another situation where the tires are spinning on the rim.
35176 (A55758)
35176 (A55758)
2007 Freightliner B2 School Bus (A55852)
2007 Freightliner...
2021 Ram ProMaster City Van (A56858)
2021 Ram ProMaster...
40006 (A55788)
40006 (A55788)
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A55315)
2023 Unverferth...
