My solution to the ROPS pin
   / My solution to the ROPS pin #21
Stress on the pins during a roll over probably isn't that high. For a true sheering break you would have to roll upside down and then slide forward forcing the top half of the roll bar to try to fold down.
   / My solution to the ROPS pin #22
Interesting that they would put a cat 2 on a tractor that couldn't fit it.
I'm going to assume that you must have the one piece wheels on yours.
No, it has the two piece wheels. I wasn't thinking about that when I mentioned the spacers.
The point is, I don't want the tractor any wider than it is, 6 feet. The blower is 78 inches wide so I want the tires inside of that and I don't need chains so no need to move them out.
Ok, UPS delivered the modified pins from my son.
I had to drill out the hole for my lynch pins. The hair pins that came with them were really small.
I installed them on the tractor. The pin does not insert completely (planned) as it is stopped when the 5/8" diameter reaches the threads of the welded on nut. The 9/16" portion continues through the nut and the lynch pin secures it. There is ~1/8" of play before the lynch pin hits the frame of the rops. The 5/8" diameter portion is still completely through the frame.
No more 'screwing around"!
Thanks Adam!
   / My solution to the ROPS pin #25
If they vibrate you can always put an o-ring or two on the pin so they compress slightly when you put the pin in.
   / My solution to the ROPS pin #26
Could the ROPS vibrate enough to shift slightly when the pin is out and make re-insertion of the factory pin difficult or impossible?
2020 JLG 1732 4x4 Rough Terrain Telehandler (A49461)
2020 JLG 1732 4x4...
2016 New Holland Boomer 47 4WD Front Loader Utility Tractor with Bush Hog BH16-2 (A50322)
2016 New Holland...
Hotpoint DBL1550BALAD Dryer (A50860)
Hotpoint...
2008 John Deere 3520 Tractor (A50860)
2008 John Deere...
Toolbox (A50860)
Toolbox (A50860)
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2023 PETERBILT 579...
