My kubota zd321 will not start, sometimes it will for no obvious reason.
   / My kubota zd321 will not start, sometimes it will for no obvious reason. #1
Havana, IL
Kubota ZD321
Hello, I need help. I have a kubota zd321 zero turn mower. Half the time we go to start it, it will fire up fine. Half the time we get nothing. I have checked all safety switches with a meter and they are good to go. I am stumped however I have a hunch about two things was hoping someone could maybe help me. When I turn the key to start the mower, after letting it do it's warm up, it will start immediately sometimes and other times it will have to be held for seconds before it turns over. Worst yet I cannot get the cover off too get a meter on the switch. I got a new battery too btw. Also there is always this clicking that I hear when I shut it off I'm not exactly sure what that is but sometimes it will not click and I think that might be a issue. Any help would be greatly appreciated. Thanks
   / My kubota zd321 will not start, sometimes it will for no obvious reason. #2
That clicking is the fuel stop solenoid. When you turn the key on you should hear a click. This the solenoid pushing the fuel control lever open. The delayed click you hear after shut down is the solenoid retracting.
The fuel stop solenoid will be on top of the engine, a small round (about 2-3" in diameter) gold colored canister with rubber on it's base and wiring. Open your hood then turn the key on (do not start). You should be able to see the solenoid activate. If it does not move, you can manually push the lever open and it should start when you turn the key fully on. If this is the case, you will need to replace the solenoid, a very easy job- about 5 minutes.
PS: Welcome to the forum!
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2021 McFarlane IC-5140 Vertical Tillage Tool (A50657)
2021 McFarlane...
2015 MACK GU713 (A50854)
2015 MACK GU713...
1986 CATERPILLAR D6H HI-TRACK CRAWLER DOZER (A51242)
1986 CATERPILLAR...
2006 IC PB30500 School Bus (A50323)
2006 IC PB30500...
2003 JOHN DEERE 350D OFF ROAD DUMP (A51242)
2003 JOHN DEERE...
