Grumpycat
Super Member
Wash the tank out first.These plastic welders. How do you not blow uourself up, when welding a fuel tank?
Temperature is only 600-700°F.
With diesel fuel that is not a concern.These plastic welders. How do you not blow yourself up, when welding a fuel tank?
Diesel is just much less explosive than gasoline. And also, a plastic welder is just a soldering iron, basically, and there is only heat and no 'spark' involved. I'd definitely drain the fuel tank and keep the cap open when doing the work but with a diesel tank that seems pretty low risk.These plastic welders. How do you not blow uourself up, when welding a fuel tank?
