Walter L
- Joined
- Nov 19, 2006
- Messages
- 352
- Location
- Delhi LA
- Tractor
- LS XG3135, Foton FT404,Farmtrac 555 ,Kubota L245H offset garden tractor Mahindra 2660 cab tractor
I have used the tractor with a disk, scoop, box blade, Log tongs on a bar and post hole digger for 10+ hrs so far.
The tractor is brute strong, starts easy even on cold mornings easy to drive and comfortable, most of the controls are well placed for me with the exception of the left brake, it is so small that my big foot covers the left and part of the right brake, the right brake when pressed hard I sometime hit the foot fuel feed or accelerator, accelerator pedal could be a little shorter and would probaly solve that issue. The engine on the Foton (4 cylinder) C490BT runs smooth and strong up to 1600 RPM and above 1600 RPM it has a vibration that is not real bad but bothersome and it does not smooth out at higher RPM, I have been told that this is normal for this engine.
All the fluids were changed by dealer except the front drive, I drained, flushed and refilled with 80- 90 wt, re changed the engine & filter, governor oil, power steering fluid & antifreeze after 5 hrs and found a good bit of fine steel particles on the oil plug magnet that I consider normal. I also checked the valves on the engine at about 5 hrs found one exhaust way to tight, one intake OK and all other a little too tight, plan to check again at about 50 hrs.
I found a few nuts, studs and hoses loose in the inspection before and after I ran it in.
I am very satisfied with the fit and finish and power of this tractor the only minor annoyance is the Engine vibration and brake pedals.
Walter
Walter
