Must haves for New Tractor
   / Must haves for New Tractor #21
I forgot to add a battery charger/maintainer to my earlier post. Tractors sometimes sit without starting for extended periods, particularly in winter. Nothing more maddening than a dead battery, especially when you really need the tractor to do something with right then. I mounted a small onboard charger near the battery on mine, then routed the plug out from under the hood a couple of inches, so I can plug it in without having to raise the hood on the tractor. Works for me!
Thanks all for the very insightful inputs... Just back from a long day getting a bunch of high school kids to finish up fencing our farm... Reading through all the comments and additional links - good information...
Updating the list from all the comments and from other linked posts... Separated into groups
Maintenance Items
1. Grease gun - leaning towards Dewalt battery operated
2. Grease - Lithium with Moly ?
3. Lock-N-Lube grease coupler
4. 1/2 Torque wrench
5. New Socket set (possibly)
6. Workshop Manual
7. Service Record book
8. Batter charger / maintainer
9. Extra pins
10. Spray wax lube
11. Mechanics creeper chair
Operating Items
1. Diesel Fuel Can
2. Tub (Rubber) to store Fuel cans
3. Tool Box
4. Chains
5. Spinner Knob
6. SawHaul chainsaw carrier
7. Bucket Chain Grab Hooks (With high tension bolts)
8. LED Work Lights
9. Implements storage - Wheeled pallets, Lumber
Implements and Attachments
1. Pallet Forks / w Headache Rack
2. Ballast box / Weight Bracket & Weights
3. Receiver Hitch
So far today, purchased
Tractor Supply: Diesel Can (No-Spill), Grease Gun (Dewalt battery operated), Grease tubes (Travelers Extreme duty), Coupler
Home Depot: 2x Chains, Torque Wrench (Husky 1/2" 50-250 ft. lbs.), Breaker bar (1/2")
Amazon Ordered: Lock-N-Lube
Next on list - Bucket chain grab hooks, LED work lights, Pallet Forks, possibly a newer set of sockets (Hard to find what sizes are needed - I have a Tekton set that goes up to 1-1/4" and 24 mm), extra pins, a tool box
Hunting for a Service Manual - Any leads ?
Thanks again..
   / Must haves for New Tractor #23
Congratulations on the mahindra, I have the 1626 hst and it痴 been great
   / Must haves for New Tractor #24
I have a friend that keeps his extra tubes of grease in the refrigerator because of the summer heat. Not in the house, but the shop.
   / Must haves for New Tractor #25
Congrats onthe new tractor, If you plan on using the loader for digging or brush clearing of any kind, i would get a toothbar right away they are great , i have 2 standard tooth bars and a pirahna bar. either is good but i beleive the pirahna is actually better for digging. Also a good toolbox or several like i have on my 2538 are a must.
Good info - Thanks ! I have a refrigerator at the farm - will put the tubes in there and see what the wife says when she sees it in there :)
Will look into the Pirhana Bar - Looks solid...
   / Must haves for New Tractor #28
I vote for a fiberglass roof.
   / Must haves for New Tractor #29
How many H.P and what was the cost?
   / Must haves for New Tractor #30
rushipa
Just brought a Mahindra 1626 with backhoe... First time owning a tractor... Wondering what are the must-haves and and brand / type recommendations... so far my list is:
1. Diesel Fuel Can
I have steel and PVC fuel containers. I prefer PVC. Tuff Jug is the brand I like. With Tuff Jug design tractor filler opening bears some of the full fuel container weight.
Your fuel consumption will be 1/3 gallon per hour. Five gallons will last you 15 engine hours, which will be three, probably four days of home tractor operation. Buy FRESH diesel for only one month at a time. Almost empty tractor fuel tank before refilling. (Average residential tractor use is 60 engine hours per YEAR.)
tuff jug diesel container - Google Search
U sure it isn't HDPE? Most gas containers seem to be that, and not pvc.
4 Unused Montreal ST205/75R15 Trailer Tires (A55787)
4 Unused Montreal...
2015 CATERPILLAR 272D2 SKID STEER (A52707)
2015 CATERPILLAR...
LMC Quick Attach Hay Spear (A56469)
LMC Quick Attach...
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
2000 INTERNATIONAL 4900 CAR HAULER (A57880)
2000 INTERNATIONAL...
3' X 6' METAL SHOP TABLE W/ VICE (A57192)
3' X 6' METAL SHOP...
