Mud Grip Tires to replace the Turfs on my 855
   / Mud Grip Tires to replace the Turfs on my 855 #31
There were a couple of companies on the aftermarket who built cabs for the 55 series. I'm not aware of any making them new. I've been contemplating adding a canopy with front supports tying into my loader mounts. Partly to add safety but also as a means to push branches out of my way before they hit me. :D
   / Mud Grip Tires to replace the Turfs on my 855 #32
I have the Goodyear version of those on my Kubota B2400. They were on it when I got it 10 years ago. I'm surprised that I don't see more of them. They are easy on the lawn. Good on the gravel driveway and seem to do ok in the snow. The only disadvantage to them I see is a large footprint in the garden.
Sent from my iPhone using TractorByNet
   / Mud Grip Tires to replace the Turfs on my 855 #33
Mine is actually a Curtis Cab , in the summer I remove the windshield and doors which makes it a canopy. I did search high and low and finally found this one 2 1/2 hours away , only took like 7 years to find it
   / Mud Grip Tires to replace the Turfs on my 855 #34
I've been on the hunt to get one too... and my luck when I've seen one they are either on the other side of the country or more money than I can spend.
Poked a hole in one already. Probably would have happened with any tire but didn't take much force to push the plug in so rubber must not be very thick or reinforced. Was hogging in some vines that had pretty big thorns. Hole is right in the edge of the tread.
   / Mud Grip Tires to replace the Turfs on my 855 #36
How many ply is the tire? I don't think my turf tires are any more plies than a typical light truck tire.
It was rated 6 ply but the sidewall reads " tread 2 plies rayon, 2 plies steel, 1 ply nylon. Sidewall 2 plies nylon."
The sidwall rating may be my downfall.
I have driven it over lots of stuff since I plugged it with no problems. Tore down an old dog pen with jagged broken concrete and cut up chain link fence yesterday.
   / Mud Grip Tires to replace the Turfs on my 855 #38
I think that's normal. Sidewalls never, to my knowledge, have the same number of plies as the tread. No need normally and ride would be hellish.
   / Mud Grip Tires to replace the Turfs on my 855 #39
The BKT's are 10 ply
   / Mud Grip Tires to replace the Turfs on my 855 #40
2016 ELDORADO NATIONAL EZ-RIDER CNG BUS (A58018)
2016 ELDORADO...
Eaton PRS0100001 145psi Rotary Screw Air Compressor (A56857)
Eaton PRS0100001...
BAT WING SHREDDER (A58214)
BAT WING SHREDDER...
STIHL GAS POWERED HAND HELD BLOWER (A58374)
STIHL GAS POWERED...
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
2012 CAT Forklift (A55973)
2012 CAT Forklift...
